Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 05-05-2008, 04:29 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE Tarmac II and KW Clubsport in stock
RCE Tarmac II(05-07 STi) finally here.
Racecomp Engineering Tarmac 2 Coilovers
Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. Damping is matched to the springrates. They are geared more for the track enthusiest but still decent comfort for street. Based off KW V3 but more aggressive springrates and damping.
http://www.racecompengineering.com/i...vers_large.jpg
$2100
KW Clubsports for 2008 STi
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts. These are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008 STi. These coilovers feature the same inox line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3s that are due out in May.
http://www.racecompengineering.com/i...bs08_large.jpg
$2199
dalesalignment&brake is offline
Closed Thread
RCE, Whiteline, H&R & KW suspension in stock dalesalignment&brake VIC Vendor Classifieds 0 05-25-2009 10:30 AM
MY '08 STI KW Clubsport coilovers and RCE Tarmac II in stock dalesalignment&brake Canada Region Vendor Classifieds 0 07-15-2008 11:42 AM
MY '08 STI KW Clubsport Coilovers and RCE Tarmac II in stock dalesalignment&brake VIC Vendor Classifieds 0 07-15-2008 11:26 AM
RCE Yellow, Black and Wagon springs in stock dalesalignment&brake VIC Vendor Classifieds 0 06-16-2008 08:47 PM
Racecomp Tarmac II and KW pre-order dalesalignment&brake VIC Vendor Classifieds 1 04-25-2008 06:17 PM
