Old 05-14-2008, 05:58 PM   #1
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Default Radiator fan not working
Well this morning I warmed up my car and went drove to work as I was down the street the Upper radiator hose blew. WTF my axle just went yesturday late for work again. I rode my little sissy bike to autopart store to get the hose and replaced it. now I started it again and let it warmed up about 20 minutes. to see if any other things are leaking and noticed that my radiator fans are not working (isn't it suppose to turn on when it reaches certin temp?) and the upper radiator hose is hard when I try to squeezed it well then I turn the heater on well those buttons to turn the heat or ac on and put the blower fan to 1 and now the fan starts to come on. can somebody help me diagnose this please I don't wanna blow up another hose. and hopefully nothing too extreme for me.
99 LGT 2.5
hangman is offline   Reply With Quote
Old 05-14-2008, 08:11 PM   #2
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Come on please help me
Old 05-14-2008, 08:19 PM   #3
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
sorry I was multitasking and double post
Last edited by hangman; 05-15-2008 at 09:05 AM. Reason: sorry I was multitasking and double post
Old 05-15-2008, 12:13 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
possible problems... radiator cap is bad. thermostat stuck closed, waterpump going out. temp sensor is broken/unplugged. Fans unplugged. Fan fuse blown, fan relay's shot.
What is your temp gauge doing? Do you have logging capability? The fans should kick on by 195 or so.
Old 05-15-2008, 08:59 AM   #5
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Ok the Temp gauge is in normal range in the middle, The fuses are not blown I've checked the one in the hood and the driver's side one also it's clearly that it's not blown. About the relay I've just replaced them from a junk yard and got like 8 of these thingsthe same results for every single one of them so I think it can't be that.
Now the tstat I will look into that this weekend most likely change it with new gaskets but wouldn't it over heat though. and the Coolant temp sensor well I can't tell because the CEL didn't come on. The waterpump I think was service @ 107K. What would be the most likely hood of this problem. I've searched around but not definitive answers.
But I going to try and replace the coolant temp sensor and tstat this weekend along with a new bottom rad hose. I've been driving around with the heat on for 2 days already just so the fans kicks in.
Any help will be appreciate Thanks.
Old 05-15-2008, 09:02 AM   #6
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Sorry I forgot to state I don't have logging capabilities rkramer
Old 05-15-2008, 10:22 AM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
so what exactly is the problem? if you are at normal temps then how do you know the fan / coolant temp sensor is not behaving properly? the fans should not need to be on all the time (especially when moving)
(apart from getting to the root cause of why you blew the rad hose - which is what would concern me)
UkNuck is offline   Reply With Quote
Old 05-15-2008, 11:05 AM   #8
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Without the fans on the rad hose gets hard (if that's what it's suppose to do) and looks like its ready to burst if the fan on its not on. And I let it idle for 10 20 minutes without the heat or ac on during that time the fan does not come on.
I think the upper rad hose burst was I think
A. It was never been change.
B. on the part where it burst there was power steering fluid on from the ps pulley like it was constantly spraying fluid to it from time to time until it finally gave up and burst.
That leak was fixed a month ago. but the weak spot on the rad hose was visible.
Any suggestion on the rad hose bursting?
Old 05-15-2008, 11:17 AM   #9
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
so are you saying the upper rad hose does *not* "get hard" if the fan *is* on? I don't see why that would be unless you are actually boiling coolant - which the temp gauge would indicate you aren't
if the hose is hard and/or blowing because the cooling system is overpressurized at normal coolant temp then I'd be thinking headgasket...
Old 05-15-2008, 11:45 AM   #10
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
HG ? This was also service at 107K at a burlington VT Subaru dealer along with everything else that's involve in servicing HG the heads were machine and timing belt water pump.
Old 05-15-2008, 01:09 PM   #11
rkramer
Member#: 118209
2015 WRX Limitec
The hoses normally SHOULD get hard, the cooling system holds 10-15 psi of pressure when at normal operating temp. Any more shouldn't burst the hose unless it was old and was about to go anyway, as the excess pressure should go into the overflow LONG before the host has reached its normal burst pressure.
Old 05-15-2008, 01:37 PM   #12
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
so about the fan should I change the coolant temp sensor as it might be old not sending the right info to computer vs broken and throw a cel. The other dummy cts i shouldn't replace as readings are in the normal position when warmed up ? But anyways does the fan has something to do with rad hose burst along with old and was never change ?
Old 05-15-2008, 06:16 PM   #13
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
NM the fan kicked in after a long and impatience wait. But for anyone that encounter this kind of problem here is my 2 cents:
When coolant temp sensor reached a certain level it sends the info to the computer and computer sends relayed signal to fan. Since coolant temp sensor is a sensor defects to it would trigger a CEL in my case it didn't because nothing is wrong with it. The upper and lower rad hose hardens like it was about to burst it will if old and power steering fluid constantly shooting at it but when fan kicks in the hoses gets soft again this is what happens when you're paranoid about the hose bursting I'm sorry for wasting all you guys' time
But I'm still planning to change the tstat and lower rad hose this weekend anyways and flush cooland while Im at it.
Old 05-18-2008, 04:22 PM   #14
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Mission accomplish flush new tstat new lower rad hose.
Radiator fans not working correctly, Long term issue Jpizzzle Electrical & Lighting 5 04-12-2010 10:53 PM
radiator fans not running? mikey-babo Service & Maintenance 1 09-14-2005 02:03 PM
Car overheating & radiator fans not turning on SlowPoke00 Service & Maintenance 10 02-08-2005 02:19 AM
Radiator fan not coming on. So it seems. ebeck Electrical & Lighting 15 12-21-2004 11:40 AM
Radiator fans not coming on with link plus Midwayman Engine Management & Tuning 6 09-15-2002 01:28 AM
