Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 05-14-2008, 09:38 PM   #1
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
Default Need help with AUX control of 07 HU in my 07 TR
Hey i need some help because my new oem sti 07 HU with AUX input will not work and neither does the CD player
I installed in today and right after i installed it the HU said system check and i don't know what that means, well i started up my car and pressed the on button or volume button and it started makin the sound like the CD player was starting and i turned on the radio and it worked
but when i started trying the CD player it said press eject so i did and it started makin noise and then it said disc search. then it switched back to the radio and i tried to make the AUX work and it wouldn't even switch to the AUX to even try it and now i just need a little help or something to try and someone to tell me what i did wrong or what to do
please help
can someone tell me if there is an order or hooking up the back of the sterio to make it work correctly
breezeby is offline   Reply With Quote
Old 05-14-2008, 11:04 PM   #2
breezeby
Member#: 132658
07 TR vf39ed
after pressing the CD/AUX button this shows up and it sounds like it wants to work
i press eject and then this happens
after pressing eject button
i need some help
Old 05-15-2008, 10:22 AM   #3
breezeby
Member#: 132658
07 TR vf39ed
bump for some help
Old 05-15-2008, 04:34 PM   #4
breezeby
Member#: 132658
07 TR vf39ed
still need some help here
Old 05-16-2008, 09:34 AM   #5
breezeby
Member#: 132658
07 TR vf39ed
bump for som help still
Old 06-17-2008, 10:52 AM   #6
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
My HU was working fine, then I sent it to Lightwerkz to have the backlighting modded to blue, and when I got it back I got the same message. Did you ever get your 07 HU working after you got a "system check" message?
chrisarella is offline   Reply With Quote
Old 06-17-2008, 11:12 AM   #7
CSVT_2004
Member#: 182213
1999 Contour SVT
Did the unit not come with a factory warranty?? Is it a 6 disc or single disc unit? You should not leave discs in the HU if it is a multiple disc unit when disconnecting and reconnecting power. Also most units go through a check if it's the 6 disc and it cycles all the disc spots, which you should not be moving or jolting the unit until it has finished doing its cycle. As for AUX, have you tried plugging something into it and then pushing AUX.... some AUX ins only work if they "sense" something plugged in...
CSVT_2004 is offline   Reply With Quote
Old 06-17-2008, 11:28 AM   #8
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I have an 03 WRX and bought the 07 HU here from another member, so no I don't have a warranty. The HU worked fine for almost a year without issues.
And as far as I know, no discs were left in my HU.
The issues are that the "system check" message doesn't go away, nor can I access my Sirius satellite mode. If I power up the radio premature before the "system check" message stops blinking the am/fm will work and I get the same messages as noted above when clicking on the cd button. Then all I can do is use the am/fm mode. So I disconnect the pin connector in the back, left it out overnight, and plugged it in this morning which brought it back into "system check" mode. I waited 10 minutes and nothing happened.
Now what?
Old 06-17-2008, 12:09 PM   #9
CSVT_2004
Member#: 182213
1999 Contour SVT
Now what?
Sounds like an internal issue.... May have to take it to a dealership and have it serviced...
Old 06-17-2008, 12:40 PM   #10
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Internal to what? I only sent the face to be modded (which unclips from the body). The main body of the HU stayed on a shelf untouched. I can't imagine how anything related to the internals got damaged. Thanks anyway. It is going back to Lightwerkz to get sorted out now.
Old 06-17-2008, 12:44 PM   #11
weaponstroop
Member#: 180842
2008 WRX STi
be sure to let us know how it works out for you.
weaponstroop is offline   Reply With Quote
Old 06-17-2008, 12:47 PM   #12
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
I will. This really sux bawlz.
Old 06-17-2008, 02:01 PM   #13
CSVT_2004
Member#: 182213
1999 Contour SVT
I didn't catch weather this was a 6 disk unit or not. If it is, from what I've seen happen at our bay, we got a tech bulletain a while back about leaving disks in the unit when removing or re installing... sometimes can mess up the internal changer, even if you do this you can still have issues if your not extremely careful with them... We had an installer doing a 04 dodge ram 3500 dually for sat radio, he removed all the disks, was careful with it, and it still had issues when he was done... idk if he jolted it or what... but I always let it cycle the trays and don't put it into the dash until it has stopped making all of it's mechanical sounds.
Sorry to hear about the HU, maybe something in the face to crossed when they were modding, you did say hitting cd said eject, and eject said disc searching... maybe they got something mixed up inside.... or touching something it shouldn't....
Hope it all works out for you in the end...
Why did you go with the 07 factory radio if you don't mind me asking?
Old 06-17-2008, 04:49 PM   #14
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
It's the 6-disc changer that came in the 07 STI limited, with the iPod port, Sirius, and plays mp3/wma audio. I can look through the top venting and see there are no discs in the sleeves. As a matter of fact, the discs that were in the player before I removed it from the car are still on my front seat (all 6 of them).
And I went with the 07 factory stereo because it had everything I needed and nothing I didn't... sirius, mp3 playback, ipod port, factory fit/finish, and low-key looks. I'm in NY and getting a car sereo stolen is typically a crime of opportunity. If I have a stereo that isn't trick and doesn't look appealing then a thief will move on to another car that will.
Besides, my whole interior has blue backlighting (including the blue defis) and I like everything to match. Finding the right aftermarket HU that had everything I wanted and matched the lighting would probably be too much to ask for.
Anyway, I just got the Sirius to work a little while ago. My iPod is charging so I'll test it out in the AUX port when it's done charging. The CD player is the main issue now. When I click load it won't accept a cd, then says to click eject, but there is nothing to eject. Clicking eject brings me back out of CD mode to the radio mode. I can look through the top and see there are no CDs in it so that isn't the problem. I'll try pulling the face and re-seating it and go from there.
Old 06-17-2008, 07:25 PM   #15
CSVT_2004
Member#: 182213
1999 Contour SVT
Sweet, very good choice then Didn't know it had sat, sat is a nice feature. did your car already have the parts for doing sat or did you have to add it?
Old 06-17-2008, 08:35 PM   #16
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
No, the the Sirius antenna wiring had to be run from the stereo, behind the dash, up the a-pillar, across the headliner and next to the rear-view mirror. It wasn't that bad though. It connects via Cnet connector behind the HU. iPod port has replaced my ashtray. I wish I could've mounted it in the glove box or center console but the provided cable wasn't long enough.
BTW, iPod is working now too.
Now I just need to get the CD changer going again.
Old 06-18-2008, 02:12 AM   #17
CSVT_2004
Member#: 182213
1999 Contour SVT
Well that's a step in the right direction at least...
Need help with RAID controller options White 2.5rs Off-Topic 4 05-10-2009 02:18 AM
need help with purge control skatefather Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-17-2008 01:42 PM
Need Help with Boost control Problem sz49/EWG/MBC Zornorph Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 03-11-2007 10:32 AM
need help with aux in on alpine 9856 imprezar25 Car Audio, Video & Security 3 12-05-2006 11:35 AM
Need help with Ground Control installation skyliner33v Brakes, Steering & Suspension 3 12-24-2001 06:07 PM
