Old 05-14-2008, 10:52 PM   #1
bebemaster
Member#: 111687
2005 wrx wagon
black
Default Andrewtech TurboXS hybrid 2.5 vf39 build
Picked up my car today. Heres the plot without further ado.
Modds 2005 wrx wagon
2.5 Block
Modded injectors
Walbro Pump
VF39
UTEC Delta
Prodrive Oval axleback
TurboXS stealthback with high flow mid cat
TurboXS topmount
Liking the low torque for a DD and still on the stock gears so I am quite happy unless my fund situation changes.
bebemaster is offline   Reply With Quote
Old 05-14-2008, 11:12 PM   #2
sjs0433
Member#: 86061
I feel like the hybrids with higher compression should be making numbers very close to the sti but they always seem to be a bit low. I'd have though that setup would easily put you at 300whp.
sjs0433 is offline   Reply With Quote
Old 05-15-2008, 08:36 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
nice numbers..
Old 05-15-2008, 08:59 AM   #4
wrxhard
Member#: 108091
Originally Posted by bebemaster View Post
...I am quite happy unless my fund situation changes.
So basically you're saying you like your car until you find some money, then you will spend said money on your car???
wrxhard is offline   Reply With Quote
Old 05-15-2008, 09:23 AM   #5
bebemaster
Member#: 111687
2005 wrx wagon
black
Yeah its time to get back to spending some on suspension for a bit. Then 6-speed then back to power. So yes you are correct except I don't see myself falling into that kind of money for some time so it also means ill be happy for a few years. A dominator 3.0 looks pretty sweet but I just can't go there unless I'm ready for a new trans. Thin ice as it is.
Old 05-30-2008, 11:08 AM   #6
Tenacious Bee
Member#: 96452
So, what to play
with next ?
The wrx heads or more specifically cams hold hybrids back. Higher compression also means a higher propensity for knock limiting timing and boost. The key to power on a hybrid is octane and cams. The cams help up top and the octane helps with timing and boost. I think anyone looking to make big power with a hybrid should run meth. I will be adding meth and cams to my hybrid over the winter. I do not expect to make much more than 320/320 even with my Blouch Dom 1 turbo until I start running meth.
Tenacious Bee is offline   Reply With Quote
Old 05-30-2008, 12:23 PM   #7
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
Great looking tune..top end really seems to fall. your peak are identical to what I had with a VF39 but i still had [email protected],600. Is that b/c of the 2L heads?
sluflyer06 is offline   Reply With Quote
Old 05-30-2008, 04:53 PM   #8
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
I've seen other posts about the top end of hybrid builds and looks like it's more of a cam issue. I've seen someone change to STi cams in the 2.0L heads and power almost flat'ns out up top rather then dropping like crazy..
icslowmo is offline   Reply With Quote
Old 05-30-2008, 05:03 PM   #9
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by icslowmo View Post
I've seen other posts about the top end of hybrid builds and looks like it's more of a cam issue. I've seen someone top STi cams in the 2.0L heads and power almost flat'ns out up top rather then dropping like crazy..
Kelford 264/272's work even better. It is definitely more the cams than the heads. Still, if you are limited to 91 octane gas whp will still be lower across the board .
Old 05-30-2008, 05:35 PM   #10
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
Turboxs/Andrewtech is MD, so this should be on 93oct.
paikman is offline   Reply With Quote
Hybrid 2.5 wrx with n/a 2.5 block turboz523 Subaru Conversions 5 03-08-2008 06:34 PM
Andrewtech/TurboXS TD04 2.0L rice wrx Proven Power Bragging 43 11-11-2007 03:22 PM
hybrid 2.5 build womensecks Built Motor Discussion 29 06-21-2007 01:39 PM
Frankenstein 2.2/2.5 Engine Build questions. Not All There Normally Aspirated Powertrain 36 06-01-2007 02:28 PM
Hybrid 2.5 SB, 2.0 Heads 9vapors Built Motor Discussion 20 04-07-2007 12:04 AM
