Old 05-14-2008, 11:32 PM   #1
bzbuzz
Member#: 116052
2011 STI ( Sold )
Default Defi racer oil temp and pressure gauge thread type
Hi,
I can't seem to find clear answer for my question..
I am looking to buy 52mm defi racer gauges for oil temp and pressure.
The vendor carries only imperial units which is F* for temp and PSI for pressure. That is fine. But for the install, What I found here is that all Defi pressure gauges are 1/8NPT and temp gauge can be either 1/8 PT or NPT based on either F* or celcius.
I need to verify this for the gallery plug that I need to buy...
Defi manual on their website says its all 1/8PT..and some says pressure is 1/8NPT...
So i want to hear from people here who actually running it..
bzbuzz is offline   Reply With Quote
Old 05-23-2008, 10:39 PM   #2
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
The pressure sending unit has a 1/8-28 BSPT (British Standard Pipe Tapered)
The temp sending unit has A 1/8-27 NPT (the american version)
Subaru part # 11024AA210 is the stock front gallery plug which will fit your PRESSURE sending unit.
http://www.sfxperformance.com/cart/cart.asp
is a part (adapter) that will allow you to put the TEMP sending unit in Subaru gallery plug if you want to.
I also hear that some people actually put the temp sending unit into a 1/8 NPT threaded bung (welded) into the oil pan for more accurate readings.
Or you can use this method:
http://www.wrxtra.com/Documentation/doc-1001.pdf
which is a oil drain plug with a 1/8 NPT threaded hole in the center for you to place you sending unit in.
And finally you can use a sandwich adapter at the oil filter for both sending units BUT you will still probably need http://www.sfxperformance.com/cart/cart.asp which is the same adapter I mentioned above.
Team Scream is offline   Reply With Quote
Autometer Procomp Ultralight Oil temp and pressure gauges grex07 Interior/Dressup/Audio & Security 8 04-21-2010 05:16 PM
WTS: Prosport Premium Oil Temp and Pressure Gauges and Remote Installation Kit BNIB skribblez32 TXIC Private Classifieds 11 07-02-2009 05:51 PM
FS: Defi Link Oil Temp, Fuel Pressure 52mm White Face brex16 Interior/Dressup/Audio & Security 14 04-03-2007 08:09 PM
Oil temp and pressure gauges ghschirtz Service & Maintenance 0 02-03-2006 09:03 PM
FS: oil plug for oil temp or pressure gauge from subaru jimtweet Private 'For Sale' Classifieds 2 03-14-2005 09:01 AM
