Old 05-15-2008, 04:06 AM   #1
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Default OEM Lamco Gauge Questions
Who here has the OEM triple "sport" gauge pack from the dealership?
On the freeway, what does your Oil Temp gauge say? (What temp?)
Mine will only go as far up as 70* C
Did you have to adjust yours?
BeBop86 is offline   Reply With Quote
Old 05-15-2008, 06:45 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The temp will vary depending on ambient temp and whether you are moving or not. 70C is a typical reading when moving at speed with moderate ambient temperatures. When stopped in traffic the readings will increase, you may see 90-100C when stopped or moving slowly on a warm/hot day.
There is no adjustment to make.
Old 05-15-2008, 10:49 AM   #3
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
But even when reving hard and such, it still wont go above 70* C
Old 05-16-2008, 03:33 PM   #4
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Is the oil pan a good area to get an oil temp?
Old 05-17-2008, 12:22 AM   #5
ringe
Member#: 49998
2007 WRX CT Stg 2
I have my temp probe in the drain plug (not ideal, but I think that's where the OEM one goes). I average around what your reading, highest I've had it was around 200-220 I think climbing I-70 to the Eisenhower Tunnel.
ringe is offline   Reply With Quote
Old 05-17-2008, 05:07 PM   #6
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Is the Gallery plug a good area for an oil temp reading?
I'm considering getting a M20x1.5 to M18x1.5 adapter to put the sensor there...
Old 06-13-2008, 04:12 PM   #7
berts2000rs
Member#: 182307
2000 impreza rs
blue
Default question about lamco guages
i just got this subaru 2000 rs with fully built motor and it has the lamco vacuum,volt,and oil temp ok now for the question there is a temp sensor inside the oil drain plug and it is leaking around the temp sensor where do i go to replace the drain plug with temp sensor? subaru dealership?
berts2000rs is offline   Reply With Quote
Old 06-13-2008, 05:21 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The only place to get a replacement sensor/drain plug is from Subaru. Unfortunately this is an expensive part, around $200.
Old 06-13-2008, 10:00 PM   #9
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Not quite the hot set up having the temp sensor in a drain plug that is going to be removed every few thousand miles to drain the oil. I have not installed mine yet and the wheels are grinding for an alternative.
nottofast is offline   Reply With Quote
Old 06-14-2008, 01:43 AM   #10
mwracing
Member#: 182321
Please don't "thread-jack" with unrelated questions.
mwracing is offline   Reply With Quote
Old 06-17-2008, 04:16 PM   #11
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
~$150, or Buy the N/A kit from SubaruGenuineParts for THE SAME PRICE!!!!! No shrowd, but you get the temp sensor, gauges (VAC, Volt, Oil Temp), the "Din" panel, and everything to install it. That's what I did, just reused my turbo gauge.
I'm trying to make/find and alternative adapter here: http://forums.nasioc.com/forums/show...1520430&page=2
FS: OEM Lamco gauge pack for '00 2.5rs. Volt, oil temp, vac Cyclops Interior/Dressup/Audio & Security 1 03-05-2009 11:19 AM
FS: OEM LamCo gauges with pod fredtga Interior/Dressup/Audio & Security 3 12-07-2008 06:34 PM
WTB: OEM Lamco gauge pod for 52mm gauges MASTERMIND65 MAIC Private Classifieds 3 11-23-2008 01:02 AM
OEM Lamco gauge pack fit in 1 DIN radio slot? WRXShawn Electrical & Lighting 2 08-15-2006 06:35 PM
oem lamco gauge cup nurvsWRX Private 'Wanted' Classifieds 0 05-14-2006 09:25 AM
