Old 05-15-2008, 11:34 AM   #1
Bet On Grey
Member#: 134690
WFC All Day
SGM
Default Just hit 9k miles and have a question
Hey guys,
I just hit 9k miles on my 2006 STi ( I rarely drive it). I was wondering what maintenance needs to be done at 9k. In the Maintenance handbook, the next tune-up interval after 7,500 miles is 11,250miles. I was told to do maintenance every 3k miles. Should I just wait until I hit 11,250 or do something now at 9,000. If so what needs to be done at 9,000. I'm assuming an oil change but what else?
Thanks in advance
Matt
Bet On Grey is offline   Reply With Quote
Old 05-15-2008, 12:13 PM   #2
jk988
Member#: 60959
'03 WRX
Minimum: Oil Change.
And if you're anal like me: Coolant, brake fluid, tranny gear oil, and rear diff. gear oil; but, then again, I do these myself so all I pay for are the fluids.
Oh yeah, one more thing: drive your car more!
jk988 is offline   Reply With Quote
Old 05-15-2008, 03:06 PM   #3
Bet On Grey
Member#: 134690
WFC All Day
SGM
^^ I probably should drive it more.
anything else besides the oil?
Old 05-15-2008, 03:28 PM   #4
agentphish
Member#: 165758
2008 Impreza 2.5i
Dark Gray Metallic
I wish I had a car that was 2 years old that I only put 9k miles...
agentphish is offline   Reply With Quote
Old 05-15-2008, 04:06 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....re-read the service schedule. It's split up by miles or months (whichever comes first). Pay special attention to the "notes" section at the bottom of the maintenance table. When following a frequent routine (like oil changes), you will likely find that the "table" may not fall in line with your specific use/application. In other words, it's not so important that you change it exactly at 3k, 7.5k, 15k, etc. since chances are that you will change the oil/filter a bit sooner in some cases. It's simpler to remember that the intervals should be at least 3,750 miles or ~3.75 months (whicever comes first). Keep a log. ....personally, I keep a log and use the Trip "B" to monitor miles in between oil changes.
Don't neglect to take note of other items on the table though (i.e. timing belt, plugs, brake fluid, etc.). .....also make sure you read all of the "remarks" (special notations) for each maintenance item as well. For my own vehicles, I always use the "severe conditions" recommendations to be on the safe side. ......I do my own maintenance as like jk988 so this is cheap and relatively easy for me to do anyhow.
Kean is offline   Reply With Quote
wow 9k miles and 3rd is gone? thesubbiewagon Transmission (AT/MT) & Driveline 222 12-04-2007 09:53 PM
Just hit 1000 Miles today NAPOTS Normally Aspirated Powertrain 20 11-06-2007 07:07 PM
NYC:FINAL POST/SALE $100 OEM REAR STI ROTORS 9k miles and dccd module ($100 also).. NotoriousD Tri-State Area Private Classifieds 11 11-18-2006 10:59 AM
FS: NY 04 Rear Sti Rotors 9k miles and Dccd Module for sale. NotoriousD Tri-State Area Private Classifieds 7 09-03-2006 07:53 PM
I just drove a 99 RS coupe and a 01 RS coupe and have a question!? DirtDevil Normally Aspirated Powertrain 4 03-02-2001 11:01 AM
Message Board Statistics All times are GMT -4. The time now is 12:36 PM.
