Old 05-15-2008, 02:36 PM   #1
Jlb725
Member#: 84189
Default Some Advice for Codes: 2123 2128
I know these codes are for the Pedal position sensor, after i replaced the PPS it still throws the same codes. Any help would be much appreciated. Some of the symptoms... the car holds boost until i shift, then it goes into a severe limp mode(the rpm's stay at 2k and the gas pedal is unresponsive until the car is shut off)
Thanks,
Jim
Jlb725 is offline   Reply With Quote
Old 05-15-2008, 09:04 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Year And Model Car!
Old 05-16-2008, 12:21 AM   #3
Jlb725
Member#: 84189
I found the problem... thanks for the quick response
Need some advice for which turbo to run... pightr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-05-2004 09:44 AM
Need some advice for which turbo to run... pightr Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-04-2004 03:40 PM
Computer Science Major: Need some advice for the future FuzzyNips Off-Topic 14 02-03-2004 09:09 AM
Need some advice for a newbie!? WRX2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-19-2003 08:38 AM
some advice for Tranny oil change hp12c Transmission (AT/MT) & Driveline 9 01-11-2002 03:12 PM
