Old 05-15-2008, 05:02 PM   #1
blueb3
Member#: 108471
Default Coolant routing?
Here's the deal, I have a 98 Forester 2.5l The heater core blew yesterday, so I pulled off to the side of the road and bypassed it. Started back up, no more spewing of hot coolant on my feet But now it's overheating!! Other than a possibly kinked hose (used the ones in there, thinking of getting a short piece instead so it's not twisted all over the place in there) what would cause that? Was running just fine before the bypass.
Heater core replaced just over 3 months ago, and the shop is giving me grief on not covering the labor but will warranty the part "IF" it's defective. Which is just another whole bag of crap which I won't get into on here.
blueb3 is offline   Reply With Quote
Old 05-16-2008, 09:02 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Air bubble in the system has it bound up
Old 05-16-2008, 10:45 PM   #3
blueb3
Member#: 108471
ooooh, forgot about air bubbles. That makes perfect sense since I introduced air into the mix when bypassing the HC. What's the best way of "burping" those out?
Old 05-16-2008, 11:01 PM   #4
The_Prodigy
Member#: 116467
2004 STi
Fix the blown heater core first before you attempt to bleed the air out. You will never get the air out if you have a leak in the system.
The_Prodigy is offline   Reply With Quote
Old 05-17-2008, 01:14 AM   #5
blueb3
Member#: 108471
bypassed the heater core. Waiting on stimulus check before I can get it fixed.
Coolant routing diagram 2.5racer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-27-2009 06:41 PM
Firewall access question: best way to route a 0.75" coolant line to the trunk? scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-07-2008 11:26 PM
Re-routing coolant in throttle body WRXCJS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-19-2008 01:59 PM
anyone have a picture of re-routed coolant lines for an oil cooled turbo? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-29-2006 01:05 PM
? about Route 80 and Route 209 in the Poconos!!! snvin Tri-State Area Forum 9 07-24-2004 08:29 AM
