Old 02-25-2002, 12:48 PM   #1
impaktedwrx
Member#: 14068
2002 wrx
aspen white
Default do i need a new clutch?
next month i plan on getting a vishnu stage 0 and the FP turbo upgrade. with all this power, will i need a new clutch/flywheel? i plan on running ~15psi . my goal is to break into 12's, 12.99999999 is good enough for me. can i get that with the stock clutch? or do i need to upgrade to an aftermarket clutch? if so, can anyone give me some good clutches to look into? thanks alot in advance
impaktedwrx is offline   Reply With Quote
Old 02-25-2002, 01:30 PM   #2
nmyeti
Member#: 4980
Default Re: do i need a new clutch?
You should be fine... i went [email protected] on my stock clutch and flywheel... it gave out shortly there after, but was fine for that run.
Depending on how you launch your car YMMV
-Nathan
nmyeti is offline   Reply With Quote
Old 02-25-2002, 01:48 PM   #3
impaktedwrx
Member#: 14068
2002 wrx
aspen white
how long after did it break down? i plan on making 1 12'sec run, than driving my car as a daily.
Old 02-25-2002, 02:04 PM   #4
nmyeti
Member#: 4980
I made 50 good drag passes on the stock clutch, and a BUNCH of street racing.
Likley lasted 150 launches.
On the 51st drag pass it started to slip... was fine to drive home, but would not hold really hard launches.
I made about 13 of those passes at the low 12 second power range.
Again, its all in how you drive and launch.
Old 02-25-2002, 04:36 PM   #5
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Plan on making one 12 sec run? That would be a shame and what about on the street. Don't you ever drop the hammer on the street?
If my clutch is still holding up yours will. I've gone to the track 5 times in 3 weeks ( 20 runs or more). I also drive my car hard on the street. I would have to say all together I've done between 50- 100, 5k launches scince buying my car. These cars aren't as wimpy as some would like you to believe.
It would be a shame to have a 12 sec WRX and never show anyone what you got.
SGOSWRX is offline   Reply With Quote
Old 02-25-2002, 05:00 PM   #6
impaktedwrx
Member#: 14068
2002 wrx
aspen white
oo sorry if you guys misunderstood. i meant 1 12sec run on the stock clutch, than infinite others on an aftermarket such as exedy or act... anyone know about these clutches?
Do I need a new clutch? kirkeemonster Transmission (AT/MT) & Driveline 11 12-16-2007 05:27 PM
Do i need a new clutch? lowranger Transmission (AT/MT) & Driveline 6 09-06-2007 07:33 PM
Troubleshooting: do I need a new clutch? Canadian 2.5RS Canada Region Forum 14 05-26-2006 03:20 PM
Do I need a new clutch? protouring72 Transmission (AT/MT) & Driveline 2 03-25-2003 02:57 AM
do i need a new clutch? 9 Normally Aspirated Powertrain 4 05-07-2001 10:55 AM
