Old 05-15-2008, 05:56 PM   #1
xCatch22x
Member#: 109018
Default 12v DC direct to DCCD?
What is the effect of this? Do I just get the diff at 100% lock or will it burn out?
If I dont have a controller then is there a way to limit the current to the coil to stop it burning out?
Cheers,
Wayne.
xCatch22x is offline   Reply With Quote
Old 05-15-2008, 06:10 PM   #2
DS1
Vendor
Member#: 111780
Burns out, one of my customers tried that.
DS1 is offline   Reply With Quote
Old 05-15-2008, 06:38 PM   #3
MasterKwan
Member#: 98961
2003 WRX
Interesting. I know the controllers send a duty cycle to the DCCD clutch. Basically 12 volts all the time's 100% duty cycle. Wonder what the max duty cycle the clutches see in real life?
I run my car at the track with an open center diff (no controller). Locking the center diff and driving like that 100% of the time will probably destroy your drivetrain, just like it would in a part time 4WD truck.
Old 05-15-2008, 09:28 PM   #4
Spiider
Member#: 13680
I run my duty cycle in all my products to exactly the maximum of what Subaru does....it's no where near 100%.
Spiider is offline   Reply With Quote
Old 05-18-2008, 11:43 AM   #5
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
place a resistor in the circuit so as not to burnout the solenoid
a6n6d6y is offline   Reply With Quote
Old 05-18-2008, 04:44 PM   #6
MasterKwan
Member#: 98961
2003 WRX
Lets say you want 4 volts on the clutch. That's 14-4 volts or 10 volts dropped across the resister. Lets say the clutch needs 3 amps to actually activate (it's probably higher).
I * E = W
10 volts * 3 amps = 30 watts of power.
R = E/I
R = 10/3
R = 3 ohms.
So, you'd want probably a 3 ohm 30-60 watt resistor to be safe.
converting Non DCCD to DCCD? SUDN RSH Transmission (AT/MT) & Driveline 5 12-03-2009 07:40 PM
How could an admin give a job candidate directions to 1600 Pennsylvania Avenue, DC 24 Off-Topic 13 07-12-2006 12:11 PM
non DCCD 5 spd conversion to DCCD Daishi00 Transmission (AT/MT) & Driveline 7 02-08-2006 10:20 PM
Carputer 1Ghz ITX 12v DC with 7" touch screen monitor pir800 Private 'For Sale' Classifieds 0 07-01-2005 10:49 PM
People that are 12v DC pros, please help. G3Red04WRX Electrical & Lighting 20 05-04-2005 11:48 PM
Message Board Statistics All times are GMT -4. The time now is 02:38 AM.
