Old 05-15-2008, 08:03 PM   #1
ImprezGC8
Member#: 119201
2015 STi DarkG Metal
2004 STi JBP Sold
Default Seatbelt Chim
I was wondering how to turn off the seatbelt chim. I got the light to go off by cutting pin 11 on the itegrated box underneth the driver side dash, but the chim is still there. Anyone know how to gfet ride of this?
Thanks,
Anthony
ImprezGC8 is offline   Reply With Quote
Old 05-15-2008, 08:30 PM   #2
06WRXturbo
Member#: 157987
2006 TR Sedan
black
http://www.wrxtuners.com/forums/f92/...-disable-9409/
don't know if it will work on ur GC8 tho.
06WRXturbo is offline   Reply With Quote
Old 05-15-2008, 08:40 PM   #3
Handsdown
Member#: 29355
unplug the chime, it's in there somewhere... is this a race car? I hope/am sure you have a harness or other retention system. the plug unplug 40x trick probably isn't what you want if you are not using the factory belt at all.
Handsdown is offline   Reply With Quote
Old 05-15-2008, 09:05 PM   #4
ImprezGC8
Member#: 119201
2004 STi JBP Sold
No this is not a race car. I am using the stock seatbelts. I have a 98 RS with a 02WRX swap (engine, dash, etc.). So pretty much my whole car harness is a WRX one done by ECS. I read on scoobymods.com to cut pin 11 on the blue connector on the integrated module under the dash to get rid of the chim/light. Well that only got ride of the light, which is not what is bothering me. I want the chim to go away, the light I don't car about.
Old 05-15-2008, 10:37 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The plug-unplug method only works on the newer cars, it won't work on a 98. You will have to physically remove or disconnect the chime unit if you want to kill it.
Old 05-15-2008, 10:52 PM   #6
ImprezGC8
Member#: 119201
2004 STi JBP Sold
Well I got the light to go off, but I was told that I can not just unplug the units because there is other stuff on the plug that is needed. I just need to know if there is another wire that needs to be cut. I cut the black/blue wire going into integrated module under the driver side dash.
Old 05-18-2008, 10:55 AM   #7
dryvby
Member#: 49931
0305 wrx/Xt
black/black
can't you just unscrew the door closed switch ( usually on the b-pillar), unplug the harness, and re-install? just a thought though as im not familiar with that car.
dryvby is offline   Reply With Quote
Old 05-18-2008, 10:30 PM   #8
ImprezGC8
Member#: 119201
2004 STi JBP Sold
Well as soon as I turn the car on the chim starts whether the door is open or not. It only shuts off when I pull the seat belt out far enough.
Old 05-19-2008, 04:31 PM   #9
dryvby
Member#: 49931
0305 wrx/Xt
black/black
Ahh..Gotcha...Must be a switch on or near the pretensioner or reciever buckle (although I doubt they wired anything in there.) I guess i'd take the b-pillar trim cover off and have a look, cut some wires, and go for a ride. Kidding. Good luck.
Australia people chim in. ikon International Forum 2 02-01-2009 12:05 PM
FP users please chim in gtasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-30-2008 07:07 PM
APS intake issues chim in gtasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-04-2008 01:58 PM
APS intake issues chim in gtasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-03-2008 06:11 PM
Anyone here use Prosport Sandwich adapter?? plz chim in downsti Interior & Exterior Modification 13 10-30-2007 08:24 AM
