Notices
Old 05-15-2008, 08:45 PM   #1
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Default 07 2.5i Fog Light Options / Suggestions
Hey,
My car did not come with OEM fogs so I am thinking about putting some on and wonder what suggestions you guys might have.
#1 Is there any aftermarkets that can go in the where the OEM's would have been?
#2 I am not looking to spend hundreds on fog lights, just something clean looking, that will be functional and semi durable and I don't mind changing bulbs every so often.
#3 I am not a wiring guru so I hope fogs are something that can be easily done without have to do tons of wiring.
#4 Any particular brands and or models that you have used that might fit the bill.
Thanks.
kero is offline   Reply With Quote
Old 05-15-2008, 09:25 PM   #2
funky monk
Member#: 143094
08 LGT
DBM
just kidding. OEM stuff should be fine, get them at your dealership.
funky monk is offline   Reply With Quote
Old 05-15-2008, 09:43 PM   #3
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
I am pretty sure they will be pretty darn expensive, I can't even find them online to see what they cost? Why in that photo is there 1 fog light hole empty and the other is covered solid with no fog??
Old 05-15-2008, 10:01 PM   #4
enrohT
Member#: 136745
2006 OBS
Navy Blue
what bumper is that?
enrohT is offline   Reply With Quote
Old 05-15-2008, 10:08 PM   #5
Handsdown
Member#: 29355
searching can answer 1+3
hella optilux 1100 and custom brackets answers 2+4
bumper is stock with an sti cover on the right. it's the rally innovations lightbar that makes it look different.
Handsdown is offline   Reply With Quote
Old 05-16-2008, 12:00 AM   #6
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
its a stock bumper with an empty fog bezel.
makes for a nice cold air induction hole
jdubya301 is offline   Reply With Quote
Old 05-16-2008, 01:04 PM   #7
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Those look good,w hen you refer to custom brackets, you mean I have to make some. I have a metal shop at work.
I assume those would mount in the air damn, not the stock fog light locations?
I assume the wiring is not that hard??
Old 05-16-2008, 02:14 PM   #8
Handsdown
Member#: 29355
wiring is simple all you have to do is get a relay and switch from another subaru and get connectors or small male spade connectors for the stock fog plugs.
if you can make a bracket, you can fit them in the stock locations... it all depends on the bracket.
you can also put them in front of the radiator, whatever works.
Old 05-16-2008, 02:55 PM   #9
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Cool thanks, will get them in a week or so and give it a go
I'm gonna pull off one of the fog light covers and see what's there for mounting, etc.
Old 05-18-2008, 01:05 PM   #10
Confused Pete
Member#: 177457
2005 Saabaru Linear
Anyone ever fit Hella Micro DE in there? I have them on my Saabaru, and they're an absolutely perfect fit.
Confused Pete is offline   Reply With Quote
Old 05-18-2008, 02:13 PM   #11
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
I was looking at those as well on rallylights website. I can't decide which ones to get, I still have to pull of the fog light cover and see what mounting options are there.
Old 05-18-2008, 02:27 PM   #12
Confused Pete
Member#: 177457
2005 Saabaru Linear
That's where I got 'em from.. seems like a good place to support.
In my case, I got very lucky as someone already did this on the 92x, and had a very nice detailed PDF write up I could print out and use as a guide. . there was a hole on either side for the factory lights that I used, and it ended up just about perfectly centering the lights, and they're set back and concealed.
I used my factory bezels but cut the "mesh" out, and it worked well.... I think the 06-07 has a similar small fog stock, so results may be similar. . These are the best fogs I've ever had, without a doubt. They actually help in poor weather, rather than just look neat. .
I guess you may need to purchase the stock fog surround / bezel to make it work...
An interesting aside that I haven't confirmed yet... the stock 92x fogs are LGT fogs. Not sure if that will help with mounting.
Old 05-18-2008, 03:31 PM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
sylvania x1010 hid
Old 05-19-2008, 12:43 PM   #14
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
I can't decide whether to go with the DE fogs or 1100 series. Either way I will have to make holes in the stock fog covers and probably make a custom bracket.
I pulled each fog light cover, there seems to be a socket behind each one, I assume that is the wiring for the OEM fog lights, just don't know how I would wire aftermarkets into those sockets unless I cut off the sockets and wire from there. I assume I would be better off wiring and not using the OEM harness/socket?
FS: 06-07 WRX 2.5i Fog Light Bezels CenOrSti Exterior/Styling 6 01-26-2010 09:18 AM
URGENT:Major issue with 07 2.5i brake lights NEED HELP 07ImprezaMB Electrical & Lighting 12 10-22-2009 01:01 AM
2008 2.5i fog lights vi3tmofob Interior & Exterior Modification 3 09-11-2008 11:31 PM
FS: 07 2.5i Tail Lights 07txsubie TXIC Private Classifieds 2 07-06-2007 11:50 AM
2006 Impreza 2.5i Fog Light Options matt_8105 Interior & Exterior Modification 1 01-02-2006 12:18 AM
