Old 05-16-2008, 12:19 AM   #1
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Default Valve seals, possible without removing heads?
I just got my new motor in and running... but it looks like I must have torn a valve seal when I put the valves in. I really dont feel like pulling this thing apart AGAIN, but I cant really see any way I can get the springs off without a big c-clamp style remover... anyone got any thoughts?
Splinter is offline   Reply With Quote
Old 05-16-2008, 06:25 PM   #2
mikeythejew
Member#: 141672
I assume you have an STI engine??? Their is an engine forum here and scooby mods.com sometimes has better "how to" info.
You can install new valve stem seals without pulling the heads. I would pull the engine out and perform this work on an engine stand.
You may need Subaru tool # 499718000 for the valve springs, and Subaru tool # 498857100 used to properly install new valve stem seals. You also should use an air compressor to keep the cylinder pressurized to prevent the valve moving while your replacing the stem.
Have fun.
mikeythejew is offline   Reply With Quote
Old 07-12-2008, 08:02 PM   #3
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Well I couldn't find a tool, so I made one
I wish Id done this when I first built my engine... this thing is awesome
Old 07-13-2008, 01:53 AM   #4
techwrtr2
Member#: 105613
2007 WRX Limited
Garnet Red
At least in the boxer engine, you don't have gravity demanding the valve drop into the engine. Did the seals in an old Buick engine once and for some stupid reason I released the air pressure holding the valve up. Things got expensive quick.
techwrtr2 is offline   Reply With Quote
Old 07-17-2008, 01:18 AM   #5
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
K I'm getting confused... This doesn't make any sense.
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Obviously I need to switch to a colder plug, but the oil is what's puzzling me. Plug 1 clearly has oil on it, but I ran a UV dye in my oil, and there's no oil in any of the intake tracts, but there's oil in the exhaust port for cylinder 3, and not cylinder 1!
Blurry picture, I know, but it's hard to take a decent picture when you're holding a UV light in one hand and a UV filter over your camera lens :P
Any idea why this would be? There's no evidence of oil getting into cylinder 1 other than the spark plug.
Old 09-29-2009, 10:12 PM   #6
motoryder
Member#: 111268
.... MLTMFA2
Sorry to bump a dinosaur, but did this ever get resolved?....Did the seals fix the problem?
motoryder is offline   Reply With Quote
Is it possible to replace WG actuator without removing turbo? gopsu Newbies & FAQs 12 09-05-2009 12:43 AM
Is it possible to remove TOB from PP without taking off the PP from flywheel? biggreen96 Transmission (AT/MT) & Driveline 4 09-07-2008 10:56 PM
Removing heads without removing block phantomsr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-11-2005 08:44 PM
Oil pan leaking can I just seal without removing? MikeWRX-NJ Service & Maintenance 2 10-04-2004 12:46 AM
Crossmember change without removing engine. Possible? Ixx Normally Aspirated with bolt-on Forced Induction Powertrain 4 08-01-2004 01:51 PM
