Old 05-16-2008, 01:20 AM   #1
bign
Member#: 107740
05 STI - WRB
01 GSX-R 750
Default P0183 with walbro
I have a 04 WRX that I had put a TRE fuel pump in with no adverse effects (other then the tiny filter causing the car to die when it went under 1/4 tank) I got a brand new walbro for cheap so I put it in today. When I started my car I got a CEL so I checked with my accessport and I got
P0183 - Fuel Temperature Sensor "A" Circuit High Input
Any clue what that is?
bign is offline   Reply With Quote
Old 05-16-2008, 01:34 AM   #2
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
did you disconnect the battery while doing the installation? try to clear the code and see if it comes back, it coulda be just a flu
qualityracer is offline   Reply With Quote
Old 05-16-2008, 05:01 AM   #3
bign
Member#: 107740
05 STI - WRB
01 GSX-R 750
Ok, I was wondering about that, I never disconnected the battery. I was on my way out the door when it happened so I just took another car. When I clear the code with the accessport do I have to reload base map and all that or does it just clear the active map. I have never cleared codes with it yet.
Old 05-16-2008, 04:17 PM   #4
bign
Member#: 107740
05 STI - WRB
01 GSX-R 750
I got a chance to research it and it looks like that code pops up for a lot of people that change the pump. Never really found a good explanation why but it seems to stay gone once you clear it so here is hoping I didn't do something wrong.
Old 06-14-2011, 10:33 AM   #5
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
Figured I'd bump this for future people searching.
I took out my stock fuel pump and inspected it, didn't disconnect the battery. Threw P0183 CEL when i started it up, cleared it. We'll see if it comes back, but it seems to be install related.
IceWilly is offline   Reply With Quote
Old 06-14-2011, 04:05 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
jesus...all these guys ****ing around with the fuel tank and pump and NOT disconnecting the ****ing battery while doing it
Old 03-02-2015, 03:18 AM   #7
rosstitute
Member#: 407956
2004 sti
white
i know this is an old thread but i just put a walbro in today in my 2004 sti and did everything right except disconnecting the battery before install! After i primed the pump and started the car i instantly got the p0183 code and after test driving the car and driving around it went off after the third start of the engine. I was about to clear it with my accessport but the car did it itself before i could get to it
rosstitute is offline   Reply With Quote
Fuel pressure regulator overrun with Walbro or Supra pump? ringmaster Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 07-18-2005 06:58 PM
Any issues with stock turbo/injectors with Walbro pump? wagon-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-27-2004 03:07 PM
CEL Po442 with Walbro GS342HP n2xlr8n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-14-2003 05:11 PM
New FPR with Walbro 255lpr fuel pump? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-17-2003 06:23 PM
Maximum HP on stock RS fuel system with walbro fuel pump Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-17-2002 03:42 PM
