#1 |
Member#: 53558
NWIC
Vehicle:2002 WRX Wagon Silver |
My AC blows. As in, it doesn't blow very much cold air. With it being 102* F here tomorrow, and assuming that we're going to have more 100*+ days this summer, I want to get it working.
I added refrigerant (R134A) to the system per instructions on the AC recharge bottle, taking care not to over fill the system. Turns out, the system was properly charged and didn't need any additional refrigerant added, but I figured I had the bottle on, might as well get the little needle right in the middle. So, there isn't a problem with line pressure in the system, and the AC belt is in good condition, with the pulley properly engaging. My next troubleshooting step is going to be to get behind the dash and clean, clean clean! so, which parts of the dash am I going to have to remove? Will it be like my BE was, just behind the glove box, or am I going to have to pull the entire dash apart? The FSM i've got doesn't cover the HVAC system or servicing it, so here I am. ![]() I'm going to be taking an AC repair/lisencing class this summer, which means a 45 minute commute twice daily. I CANNOT do that drive without AC! ![]()
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
There is nothing behind the dash to clean that will fix this problem. If the system is properly charged (which you really can't tell for sure with the gauge on your recharge kit) and the compressor is running but still doesn't blow cold air, there is an internal issue that needs to be diagnosed by someone with the right equipment and knowledge. Either wait until you complete your AC class and know what you're doing, or take it to an AC shop now.
#3 |
Member#: 53558
NWIC
Blah, since I'm in college, I can't afford to take it to an AC shop. It does blow cold air, but not very much. In the winter, it wouldn't blow hot air until you moved the slider to cold, then rapidly back to hot, with the heat at maximum.
#4 |
Trust no one
That is the symptom of a sticking temperature control lever or cable. Could be the problem with the AC as well, if the control is sticking somewhere in the middle so that some heat is always being mixed in. If that's all it is you may be able to free it up or adjust it.
#5 |
Member#: 53558
NWIC
I want diagrams so I can disassemble the darn thing and unstick whatever's the problem.
| Thread Tools | |
| Display Modes | |
| WRX front seats, door cards, dashboard, hvac system | MeshmeZ | Interior/Dressup/Audio & Security | 3 | 11-06-2009 04:06 PM |
| Nasty sour smell from my HVAC system. | Mike7 | Newbies & FAQs | 8 | 02-25-2009 01:06 PM |
| HVAC system diagnosis help | Don Arm | Service & Maintenance | 2 | 11-28-2008 01:58 PM |
| Which way does the air flow in the HVAC system? | djerickd | Service & Maintenance | 3 | 05-16-2004 06:42 PM |
