Old 05-17-2008, 03:33 AM   #1
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Default Threw a P0031 code
Threw the code today, P0031, the A/F sensor heater low circuit. It's an 02 WRX with 134k miles. Never replaced any sensors before. I tried resetting the ecu with the access port, but the code comes back on. Is it safe to drive the car before I get a new sensor?
rexman2002 is offline   Reply With Quote
Old 05-17-2008, 06:17 AM   #2
mikeythejew
Member#: 141672
I don't think it's safe to drive your car. Excess fuel can enter the exhaust system and force the cat into overtime. Fix the problem before the cat disintegrates.
mikeythejew is offline   Reply With Quote
Old 05-17-2008, 08:36 AM   #3
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I forgot to add the car is stage 2, protuned. I have a catless uppipe, and downpipe. No cats. Also borla header in place of the stock exhaust manifold.
Old 05-17-2008, 10:35 AM   #4
TedMeyer
Member#: 57414
2002 WRX sedan
Silver. Now w/ 100% 18G!
Shouldn't be an issue. I've had this CEL for 2 weeks -- took a few days to figure out the issue, test it, and a few days to get the new sensor from Oxygensensors.com (very fast), which arrived on Tues and now I'm gonna walk down to the garage to install it. I believe the P0031, which is what I threw as well, is the heater circuit for the sensor so it would only have a effect at startup. I barely noticed any difference in driving my car, though I refrained from any stoplight racing.
I did check my CEL every day to make sure I wasn't throwing any new codes -- you'd get a "rich condition" CEL if it causes too big an issue.
TedMeyer is offline   Reply With Quote
Old 05-17-2008, 04:11 PM   #5
www.rex
Member#: 77689
I have to replace the front OS as well on my '02 WRX. Just got mine from oxygensensor.com. Agreed, very good service. Delivered in 5 days into Canada. I have read access is through the passenger side wheel well. There is a plastic panel to open or remove? Ted, can you give me a description of location, appearence, size of this access panel? Anything in particular to watch out for doing this install?
www.rex is offline   Reply With Quote
Old 05-17-2008, 06:59 PM   #6
WRBLueGD2
Member#: 139108
2004 WRX
The fender liner mounts to the frame where you need to go. On the passenger side, take your tire off (It's easier) and you'll probably need a wrench as an O2 socket is very tight to get in there. You can take undo the front half of the fender liner and as you peel it back, you'll see you manifold and the wire sticking out. Very hard to miss. If you have a wrench instead of a socket and can get the car up enough, you can just take it out from underneath. When putting in your new one, be sure to guide the wires WITH the rotation of the O2 sensor so you don't ruin any wires.
WRBLueGD2 is offline   Reply With Quote
P0031 Code V8killah91 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-12-2008 07:14 PM
Threw a P0031 ... fix myself? or play it safe and have the dealer check it out? coldfire22x AccessPort 6 05-22-2008 03:49 PM
For those that have fixed a P0031 code... turd_ferguson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-08-2006 02:03 AM
P0031 Code. What do I replace? jackansi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-23-2006 10:47 AM
Throwing a P0031 Code... WrxRick Service & Maintenance 14 01-27-2006 09:19 AM
