Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 05-17-2008, 03:24 PM   #1
Member#: 61036
Default Rattle from front drivers strut
While replacing my front pads I attepted to find the rattle that has been annoying me for months. Well I found where its comming from but not what is causing it. It is definately comming from the strut, because when I tapped on it with a rubber mallet it would rattle. Would a blown strut cause that?
milehighwrx is offline   Reply With Quote
Old 05-18-2008, 08:55 AM   #2
Member#: 146626
2001 Impreza GC8
Panda on rails!
I dunno if a blown strut would make rattling noise or not. Although I used to have a car with the front right strut blown (it doesn't take bumps too well after that) but it didn't make any rattle noise.
But either way, struts should NOT rattle internally if they are installed properly. If you're 100% sure that the rattle is coming from your perfectly installed strut you should probably get it replaced. (Excuse to get something fun to put on your car!)
GentlemenStylez is offline   Reply With Quote
Old 05-18-2008, 11:07 AM   #3
Member#: 108557
2003 PSM WRXWgn STG2
Did you check to make sure the bolts attaching the strut to the chassis were tight? A blown strut generally is indicated by fluid leaking from the unit and the aforementioned issue with oscillation control when going over bumps. I would retorque all the bolts to factory spec and see if that helps.
QuikWgn is offline   Reply With Quote
Old 02-24-2013, 06:09 PM   #4
Member#: 294069
98 Forester
the tophat on my rattling strut was defective, causing the strut top nut to not be physically able to tighten it down, the nut was at the end of the threads, couldnt tighten any more, yet there was wobble room for the tophat between there, that was the rattle. Used my old tophat, problem fixed. yay
mrchyes is offline   Reply With Quote
Old 02-25-2013, 02:35 PM   #5
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Is there a reason for bumping a 4.5 year old thread other than telling everyone you fixed a problem?
Sounds like you put a newer strut mount on an older strut. This commonly causes noise issues and is the reason people stack washers or spacers under the strut mount when doing this type of combination of parts.
Scooby921 is offline   Reply With Quote
Loose metal rattling by front driver side gumby1976 Brakes, Steering & Suspension 5 08-04-2004 12:51 PM
Metallic rattle from rear drivers side?? jroberts Service & Maintenance 4 07-28-2003 01:28 PM
Rattle from rear driver side wheel...how do i fix it? CanadianWRB-WRX Brakes, Steering & Suspension 2 05-04-2002 12:07 PM
rattle from rear pasenger Strut!! GregBolby General Forum Archive 6 01-15-2001 03:10 PM
