Old 05-17-2008, 03:42 PM   #1
hosl380
Member#: 136434
2002 WRX PSM
tha bug hotness
Default Help Asap!!!!
My 1998 2.2L is giving me some issues! I put a sub in it today and ran everything through it fine (i thought)....i ran the switch for my amp off of the ABS switch....and now the car is flipping out!
the CEL is flashing rapidly, and when the key is on it sounds like a switch is turning on and off and the cooling fans turn on and off!! when it is running the CEL stays obviously but when you push the brake in and try to put it in drive it won't budge....any ideas?? or things i should check?? thanks
also while i was putting my deck in i had to keep putting it in drive because the knob kept getting in the way...maybe that had something to do with pissing the system off!?!?!
hosl380 is offline   Reply With Quote
Old 05-17-2008, 04:34 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
DANGER TO MANIFOLD!
yu gots so meny amps its kiling the circits yo!
Did you connect the green connectors?
Old 05-17-2008, 04:41 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yup bet that's what happened. Go back under the dash, find those green plugs that you connected together and unplug them. Problem solved.
Old 05-17-2008, 05:36 PM   #4
hosl380
Member#: 136434
2002 WRX PSM
tha bug hotness
ok i will do that but could this be anti-theft by any chance!?!?
Old 05-17-2008, 05:42 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No, what you are reporting is exactly what happens when those green connectors are plugged together. It puts the ECU into a diagnostic mode and the CEL flashes constantly while various relays and solenoids cycle on and off.
You are supposed to leave those plugs alone, now you know why (along with the multitudes of others who have done the same thing and made the same post).
Old 05-17-2008, 06:05 PM   #6
hosl380
Member#: 136434
2002 WRX PSM
tha bug hotness
ok sounds good, thanks for the input i will let you know how it comes out!
Old 05-17-2008, 06:27 PM   #7
hosl380
Member#: 136434
2002 WRX PSM
tha bug hotness
i took the connecters apart, the CEL's and everything stopped, but the shift lock is still engaged and i can't seem to figure out how to get it to go into drive?? any ideas?? thanks again
Old 05-17-2008, 08:03 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The shift lock is a separate issue. You may have blown a fuse for the solenoid.
Old 05-17-2008, 08:21 PM   #9
hosl380
Member#: 136434
2002 WRX PSM
tha bug hotness
i checked the fuse for that, and it seemed fine its still locked, but i am using a small screw driver that unlocks it for now until i can get it looked at!! thanks for all the input
Help ASAP! Lights Flashing After Battery Install?? ASAP!! tbcboo Car Audio, Video & Security 5 05-02-2009 12:15 AM
!!help help ! i need help ASAP yuboyus Mid West Subaru Owners Club Forum -- MWSOC 3 10-17-2006 03:16 PM
HELP Exhaust Shop HELP ASAP car_cursed Rocky Mountains Impreza Club Forum -- RMIC 5 09-07-2005 12:15 AM
Help help ASAP! eclone Brakes, Steering & Suspension 4 04-26-2003 04:06 PM
('93-'01) Help! I Screwed Up My Door? Need Help ASAP ejicon Impreza Forum 7 04-27-2001 12:03 AM
