Old 05-18-2008, 03:07 AM   #1
s1lentx
Member#: 72530
Default Headlamps don't work (05 wrx)
Hey guys
The high beam as well as the head lamp doesn't work, but the bulb does work. ive searched and heard somthing about connectors, but it seems fine.. any other possible solutions? thanks!
s1lentx is offline   Reply With Quote
Old 05-18-2008, 10:52 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If the fuses are ok then I would check the light switch to make sure it is working as it should be. It makes a ground connection I believe, to turn on the lights.
Old 05-19-2008, 03:33 AM   #3
s1lentx
Member#: 72530
i tried lookin into that but no luck... i even tried replacing bulbs but those don't light up... i noticed that the driver side has more than usual light output than the passenger when i turn on the headlights... also the high beams are dim, but are constantly on.. what is going on anyone??
Old 05-19-2008, 05:49 AM   #4
Cougar4
Member#: 53443
Winestone
Without a good wiring diagram and some testing done to see what area may be the source of the trouble it is hard to say. There may be a problem with the DRL module but that is just a guess. You may need to have a shop check the problem out.
Old 05-29-2008, 03:41 PM   #5
cdawgger
Member#: 120718
05 vf39
^ what cougar said. my friend had similar problem you should def. check the drl module
cdawgger is offline   Reply With Quote
Old 05-29-2008, 04:07 PM   #6
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
could be a broken relay
mikeis300 is offline   Reply With Quote
anyone with Seibon Carbon Headlamp Eyelids (04-05 Impreza/WRX)??? krystek Newbies & FAQs 4 10-12-2007 05:29 PM
new 04-05 JDM headlights don't work cryptoNiX Electrical & Lighting 7 06-15-2006 06:11 PM
Headlamps stopped working 2term8r Electrical & Lighting 1 08-01-2005 12:20 AM
FS:Locally, Prodrive UK300 headlamps (02-03 USDM WRX) non HID Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 31 08-22-2004 11:05 PM
Passenger foglight won't work (02 WRX) tried new bulb overdose Service & Maintenance 2 04-21-2004 12:16 AM
