Old 05-19-2008, 01:12 AM   #1
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Default WRX Suspension Swap onto BD Legacy Ride Height Issue
So I have had bugeye WRX suspension on my 97 Legacy L for about 6 months now. I have always thought it looked a little awkward compared to stock, but I never took any measurements. I took some measurements today and found a ride height in the front of about 7.5" and about 6.5" in the rear. I know my BD is lighter than a bugeye, but from everything I had read that swap is suppose to lower the ride height, not raise it. AFAIK the stock ride height on my Legacy should be 6.1". That setup is also no where near as stiff as my friend's 04 2.5RS or even my 02 Civic.
I am also thinking about doing the 04 STi suspension swap into my car this summer. Anyone have a guess as to what that ride height would be or how stiff it would ride compared to an actually STi? I rallyx and autox my car, so I want to keep enough clearance for the dirt while still having a stiff setup for autox.
Thanks
RallyLegacy is offline   Reply With Quote
Old 05-19-2008, 02:58 AM   #2
that one legacy
Member#: 103665
its pretty stiff. and if you're running tires wider than 205 or so, you'll definitely need to roll the rear fenders. i've had '04 sti struts and springs on my BG for almost two years now, and i really like it, but sometimes i get complaints from my girlfriend about the ride being too stiff.
i don't have any recent pics, but if you find any pics of my car in the Gallery thread from the past year or so, you'll see how mine sits on the sti struts. just remember that mine is a wagon, so it might sit a bit differently than your sedan.
that one legacy is offline   Reply With Quote
Old 05-19-2008, 03:20 AM   #3
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
gtwagon941 is offline   Reply With Quote
Old 05-19-2008, 03:34 PM   #4
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
I found some pics you posted on 4/07, and it looks a lot lower than mine, but I don't think it is too low for rallyx. Did you do anything to keep the back end from sagging, or are the springs stiff enough to alleviate that problem?
Old 05-19-2008, 08:14 PM   #5
that one legacy
Member#: 103665
honestly i didn't touch it once the suspension was installed. sometimes it kinds looks like the back end is sagging, sometimes it doesn't. it's really wierd. it should do just fine for rallycross, i watched a lowered VW rabbit ro rallycross one time, it was just a tad higher off the ground than mine, and it did okay. anything more intense than that though, and good luck!
one thing to worry about with STi struts is the dreaded "clunk" that they all get eventually. i've read that in '06-'07 the problem is less severe, and it was also not as prevalent in the '05 model. all of those suspensions will fit directly onto the BG/BD, but you have to have the complete set up: struts, springs & top hats, from the corresponding years.
but aside from that, it's a pretty solid set up for the street. for track use, you might want to read up some more because i know there's a lot of people out there who are less than completely satisfied with running GD suspensions on BD/BG Legacies.
Old 05-19-2008, 08:21 PM   #6
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Careful; the '05-07 STi's have a different front strut becuase the STi hubs changed.
'04 STi is the only one that bolts up to the Legacy/WRX lowers.
sybir is offline   Reply With Quote
Old 05-20-2008, 08:20 PM   #7
that one legacy
Member#: 103665
wasn't there a thread on here about a month ago where someone bolted up some '06-'07 STi suspension onto a BD? said it was a direct fit? maybe i'm thinking of something else...
Old 05-20-2008, 10:43 PM   #8
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
I have seen conflicting things between what STi supsension bolts right on, but I know for certain that 04 will. So if someone on here has actually bolted on anything but 04 STi stuff on their BD then I would be very interested to hear if they needed to mod anything to make it work.
Thanks That One Legacy for all the info. I have heard about the "clunk", but my Legacy isn't my DD so I can live with it if it developes. Typically the courses I run on for RallyX are rather smoth, so it sounds like I would still be ok as far as that is concerned. I can't wait to get the money to do it...
Old 05-20-2008, 11:33 PM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
This is how i understand it to be, though i also have only used 04 STi suspension which has the same knuckle design as the earlier legacy and impreza models share.
If you find this thread can you link it, i definitly did not see this and would be surprised to say the least if that worked.
Kawikid20o2 is offline   Reply With Quote
Old 05-21-2008, 07:51 AM   #10
gt_drifter
Member#: 61907
1998 2.5 GT
spruce pearl
i also had 04 STI struts and springs in my BD, and although many pass. thought they were too stiff they were never enough for me. i also do rallyx and autox and nasa events.
gt_drifter is offline   Reply With Quote
Old 05-22-2008, 12:50 AM   #11
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Are you all saying it is just as stiff as an STi, or does it actually feel stiffer than an STi? I don't know if the fact our cars are lighter could effect the perceived stiffness or harshness of the ride.
Old 04-03-2012, 02:28 PM   #12
fullCircling
Member#: 290547
back from the dead for more input from people running these on a BD
bump
fullCircling is offline   Reply With Quote
Old 04-03-2012, 03:03 PM   #13
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
You can use 05+ sti suspension on 5x100 cars by slotting the lower mount on the front struts. Its been done and works fine but easier to get 04 sti struts.
Go to sl-i.net. more legacy info than here
PMDSOA is offline   Reply With Quote
2002 WRX suspension on a '97 LGT ride height. Yes I searched! Dobes Legacy Forum 5 12-24-2009 12:12 AM
WRX suspension on GC8 2.5RS - ride height? Dave240 Brakes, Steering & Suspension 3 07-13-2009 08:27 AM
Suspension options for '02 WRX suspension-swapped BD mattwalters Brakes, Steering & Suspension 10 12-06-2007 12:32 PM
suspension Guru's please HELP (camber, ride height differences and rubing) MO REX Brakes, Steering & Suspension 3 04-13-2005 11:33 PM
Ride height issues after springs on GC wagon dexterous Brakes, Steering & Suspension 7 12-31-2004 11:51 AM
