Old 05-19-2008, 01:06 PM   #1
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
Default Oil Leak Location Pictures
There was a post a while ago that dealt with oil leaks and the person had pictures of the various locations where the oil can leak from as well as the solutions for each problem. I am trying to find that post but I'm not having much luck. Has anyone seen the post I am referring to and if so, can you post the link.
Thanks in advance.
Regards,
Ramon_12345
Ramon_12345 is offline   Reply With Quote
Old 05-19-2008, 11:38 PM   #2
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
IDK about the pictures but oil leaks are usually from defected seals Cam seal crankshaft seal oil pump O ring seal. It would be fortunate if the Oil pump seal and crankshaft seal are leaking because to replace the seal its the same laborit's easily spotted in the middle front portion of the engine.
Cam seal, you can notice this because the you'll noticed that the leaks are from the left or the right side well and for the labor there are a few extra step for this.
MYLGT is leaking from the oil pump O ring I think but anyways I just drain the oil and put GUNK stop leak it hasn't leak since but just waiting for the Service tool to arive so I can have lots of fun with this.
hangman is offline   Reply With Quote
Old 05-20-2008, 03:44 PM   #3
Ramon_12345
Member#: 72021
WHITE
Does anyone have a picture of the oil pump o-ring seal as well as an idea of it's location. Any help would be greatly appreciated.
Old 05-20-2008, 07:34 PM   #4
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
The oil pump O ring is located behind the pump itself so therefore the oil pump needs to be remove to replace it. This is what it looks like on the side that attach to the engine block the note the big hole the crankshaft seal are to be replace on the other side and the 2nd bigest hole is you guess it.
It's not the smaller 2 hex key that almost looks like the block drain plugs.
Oil leak, undertray off, pictures inside, where's it from? wilsa Factory 2.5L Turbo Powertrain 4 04-09-2010 07:27 AM
- Turbo Oil Leak? Pictures Inside - - Dash - Factory 2.0L Turbo Powertrain 7 03-16-2009 10:23 PM
how to locate oil leak, HELP!! xblaze1one Factory 2.0L Turbo Powertrain 10 04-09-2007 12:39 AM
Oil leak location? hawksoob Service & Maintenance 6 02-05-2004 09:50 PM
How do I locate the source of an oil leak? Rusty the Scoob Service & Maintenance 3 08-20-2002 09:06 AM
Message Board Statistics All times are GMT -4. The time now is 12:46 PM.
