Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 05-19-2008, 08:27 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default KW, RCE, Whiteline Suspension products
RCE Tarmac II(05-07 STi) finally here.
Racecomp Engineering Tarmac 2 Coilovers
Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. Damping is matched to the springrates. They are geared more for the track enthusiest but still decent comfort for street. Based off KW V3 but more aggressive springrates and damping.
$2100 plus shipping
KW Clubsports for 2008 STi
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts. These are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008 STi. These coilovers feature the same inox line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3s that are due out in May.
$2199 plus shipping
04-07 WRX , STi and 05+ STi Suspension
22-24mm adj. front swaybars
http://www.racecompengineering.com/i...sway_large.jpg
22-26mm adj. rear swaybars
Adjustable front and rear endlinks and solid rears for WRX
Roll Center kits
http://www.racecompengineering.com/i...tsti_large.jpg
Anti-lift kits
http://www.racecompengineering.com/i...LALK_large.jpg
Rear subframe locking bolts
Rack bushings
RCE Yellow, Black and Wagon springs
RCE adjustable front camber plates
RCE rear strut tops(pillowball)
Other Suspension Products Available
Cusco swaybars, coilovers and stressbars
Ohlin coilovers and fixed perch struts
http://www.racecompengineering.com/i...trut_large.jpg
http://www.racecompengineering.com/i...over_large.jpg
RCE cool brake ducts
Please PM me for pricing and availability(on products not listed)
dalesalignment&brake is offline
Old 05-20-2008, 10:27 PM   #2
Member#: 173316
'13 BRZ
UPDATE
RCE Wagon springs are still at the sale price.
RCE Kool Brake kits are coming, excellent for the track gurus that need extra brake cooling.
http://www.racecompengineering.com/i...duct_large.jpg
A few more sets of RCE Tarmac II(05-07 STi) and KW Clubsports(08 STI) enroute.
http://www.racecompengineering.com/i...vers_large.jpg
http://www.racecompengineering.com/i...bs08_large.jpg
RCE adjustable front camberplates(non-lowering) and rear pillowball upper mounts are here.
http://www.racecompengineering.com/i...esNL_large.jpg
http://www.racecompengineering.com/i...alls_large.jpg
Old 06-02-2008, 06:33 PM   #3
Member#: 173316
'13 BRZ
Bump for good suspension
Old 06-08-2008, 02:11 PM   #4
Member#: 173316
'13 BRZ
Few more sets of RCE Tarmac II and KW Clubsports(2008STI) in stock.
Full range of Whiteline Suspension parts are also available.
Old 06-10-2008, 01:00 AM   #5
Dantes Inferno
Member#: 126027
Any GC8 systems?
Dantes Inferno is offline
Closed Thread
Genesis Performance: Whiteline Suspension Products, Awesome pricing w/ FREE S/H!!!! Genesis Performance Suspension/Brakes/Handling 23 09-20-2010 04:37 PM
Whiteline Suspension for '08+ STI and WRX coming!!! KW and RCE also in stock dalesalignment&brake VIC Vendor Classifieds 3 05-24-2009 12:19 AM
PTUNING: Complete Whiteline Suspension Products for the WRX & STi Ptuning.com MAIC Vendor Classifieds 14 06-23-2008 03:36 PM
WTB: whiteline suspension products moonlightspoon Private 'Wanted' Classifieds 3 01-27-2005 10:20 AM
