Old 05-20-2008, 01:58 AM   #1
Mightyeldo44
Member#: 180453
2002 Wrx
Default Cel p0304 and tons o fun
Ok so i sold my integra last week and bought a 2002 wrx, The previous owner Instald a Vf37 ihi turbo, sti injectors, walbro 255 fuel pump, 3 inch cat back, turbo xs boost controller, and turbo xs fuel manegment. set at 19psi The car ran perfect for the first few days i had it, untill i put a wide mouth invidia down pipe to full 3 inch exhaust out. It ran fast like that for a few hours then i opend it up on the freeway and it hit 20 psi and choked out. so i turn the boost down and it runs up to around 15 psi and sputters till red line in 3rd 4th and 5th gears. its bin doing this for the past few days ocasionaly throwing a misfire code on the 4th cylender after its sputtering/choking. then at the gas station today i notice a small amount of smoke from under the hood and there is coolant sprayed all over the front of the engine. i cant tell where its coming from or why it would mysteriously start leaking, does anyone have any ideas or comments?
a few things to note.
Im from alaska and we have 90oct. gas here and turbo xs base map is for 93oct, the previous owner said he has the timing turned back 3 degrees across the board.
Im 17 years old and im not that familar with turbo cars so lets keep the negitive comments to a minimum
There is no good tuner machanics up here
Also there is a loud screeching noise that sounds on a cold start up.
Mightyeldo44 is offline   Reply With Quote
Old 05-20-2008, 09:44 AM   #2
am3rican
Member#: 67264
2008 Subaru WRX
Obsidian Black
The loud screeching is one of your belts. It's normal.
My only suggestion would be to have your car tuned with the downpipe on as with any subaru, you should have it reflashed when installing a dp or up. In the meantime, put the stock downpipe back on and see if you are having the same issue.
am3rican is offline   Reply With Quote
Old 05-20-2008, 10:21 AM   #3
prometheum
Member#: 92003
04 bicycle!
post in the alaska forums, ask jerry or chris for help
prometheum is offline   Reply With Quote
HELP - CEL P0302 and P0304 = Misfire on Cyl 2 and 4! dexterous Normally Aspirated Powertrain 8 04-14-2005 11:38 PM
Tons of fun with CELS and Old Mods mxg286 Tri-State Area Forum 9 07-30-2004 05:45 AM
CEL p0304 02SilverRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-07-2004 12:53 PM
got my new camshaft sensor for my CEl - P0304 i think Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-26-2002 06:36 PM
CEL P0304 - Cylinder 4 Misfire Detected Evan J. Kelly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-08-2002 11:10 AM
