Old 05-20-2008, 01:35 PM   #1
morrocco88
Member#: 104098
1997 LGT 2.1 stroker
Rotated S200SX-56 6speed
Default 05 LGT 4.11 rear diff fit in wrx?
I have an 03' wrx drivetrain swapped into my 97' legacy, but wanted to see if an 05' LGT rear diff will bolt up the same as a wrx? So has anybody put an LGT diff into their wrx to change final drive?
I did search, but couldn't find the answer.
Thanks!
morrocco88 is offline   Reply With Quote
Old 05-20-2008, 06:34 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
If you are changing the rear final drive you will need to change your front final drive as well.
03 WRX has a 3.9 front and needs a 3.54 rear ring and pinion to work.
minifreak is offline   Reply With Quote
Old 05-21-2008, 12:33 AM   #3
morrocco88
Member#: 104098
Yeah, I'm planning on changing the front diff in the way of an 05' LGT tranny, which came with a rear diff, but just wanted to make sure it will work, or will I have to get a 2.5rs 4.11 or something.
Old 05-21-2008, 10:45 AM   #4
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
legacy center diff is 1:1, not like wrx 1:1.1.
so if your legacy has 4.11 in front, get 4.11 for the rear.
Old 05-21-2008, 10:47 AM   #5
darksc00by
Member#: 102140
your mom
this man speaks the truth!
not going to work unless you get some custom mad tyte front diff made.
darksc00by is online now   Reply With Quote
Old 05-21-2008, 03:01 PM   #6
morrocco88
Member#: 104098
Custom mad tyte diff?
I have a complete LGT tranny out of 05', and it does have a 1 to 1 center, so I know I need a 4.11 rear end to match, which I have from the same 05' legacy, but just need to know if it bolts up the same as other R160's, or specifically the 03' wrx, because I have that in my car right now. I'm thinking it does, but just wanted to make sure.
Old 05-21-2008, 03:33 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Just curious why you would think it doesn't fit? I have a 6 r160 in front of me with different ratios and from different years and are essentially identical.
As far as EJ based Subaru's go there are only two differences that could get you -
Male VS female axle stubs (wont be a problem for the two cars you mentioned)
Mounting studs of different lengths (if they are different its REALLY easy to swap them)
Old 05-21-2008, 04:39 PM   #8
darksc00by
Member#: 102140
your mom
We were saying WRX transmission plus LGT rear diff won't work.
Yes WRX motor will work with any EJ series transmission and rear diff.
Old 05-21-2008, 08:59 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
What if he took the LGT rear diff and swapped the WRX ring and pinion into it!
I think the OP needs to be more clear in his first post.
FS in MA: 05 LGT transmission (=JDM STI) + 4.11 rear diff unclemat Drivetrain 22 12-11-2008 04:53 PM
FS in MA: 05 LGT transmission (JDM STI) + 4.11 rear diff unclemat NESIC Private Classifieds 6 12-10-2008 10:48 AM
STI Rear diff fit in a 05 WRX? ng_wrx_05 Transmission (AT/MT) & Driveline 9 01-10-2007 03:24 PM
IN. WTB: 4.11 rear diff for 98 rs needed cavakilla Private 'Wanted' Classifieds 1 10-05-2005 09:23 AM
JDM EJ20G w/ 4.11 rear diff in my '03 wrx? drunkguy Transmission (AT/MT) & Driveline 2 05-04-2004 09:36 PM
Message Board Statistics All times are GMT -4. The time now is 01:59 PM.
