Old 05-20-2008, 08:49 PM   #1
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Default What would the Airbag light, no clock, and no radio all have in common?
I'm assuming I blew a fuse but checked the Airbag fuses (in fuse box near steering wheel) and both are fine. It occured after I removed an aftermarket boost gauge I had installed and failed to disconnect the battery prior to uninstall being a dumb ass . Any suggestions?
EDIT :
I did not go through the clock pod as I only had 1 gauge and it was mounted on my steering column.
I have a 07 wrx.
I wired everything with fuse taps directly into my fuse box (located next to steering wheel)
I do have 1 loose white wire that I believe was run to the back of my stereo and will be checking that tommorow
wrxnova1 is online now   Reply With Quote
Old 05-20-2008, 10:42 PM   #2
Pick9811
Member#: 175050
2006 Impreza WRX STi
Arrow
I am still very new to the Subaru so I can't speak with any certainty... but I had a similar problem with my Dodge Ram truck (the vehicle before my Subie), and I think the fuse that blew was actually under the hood. I would check all your fuse panels (I would actually pull the fuses to check them) before tearing the car apart looking for the problem. Of course, someone else that has a ton of Subaru specific knowledge can probably draw you a map of the entire electrical system and tell you exactly what the possibilities are.
Have fun,
Pick
Pick9811 is offline   Reply With Quote
Old 05-21-2008, 02:23 PM   #3
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
if it is a fuse...it would be the one under the hood. When I had my gauges put it...my airbag light was on and my blinkers didn't work. A fuse was blown..
ThreeEleven is offline   Reply With Quote
Old 05-21-2008, 05:22 PM   #4
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Problem solved :
After using fuse taps the regular fuse wasnt going in far enough into the board SO I bent the tabs in different directions and it works.
The saying "throwin a hot dog down a hallway" applies here.
Do the 06-07 imprezza, wrx, and outback hatch all have the same trunk? hookedontronics Interior & Exterior Modification 5 10-13-2009 03:05 PM
What do a dolphin and a young boy have in common? Neek Off-Topic 4 06-11-2007 01:21 PM
What does Guy Pierce (Memento) and an ugly girl have in common? somebody else Off-Topic 9 08-13-2006 09:03 PM
airbag light is on and no cruise control wreckedWRX Service & Maintenance 3 01-24-2005 10:26 PM
What do the MRT cat and Chernobyl have in common? Julian Normally Aspirated Powertrain 2 09-23-2002 06:09 PM
