Old 02-26-2002, 04:54 AM   #1
Mike Smith
Member#: 744
00 BRP RS Coupe
02 Forester, 00 S-10,
Question Best fuel additive?
There's so many out there now (STP, Gunk, etc.), is one really any better than another?
Mike Smith is offline   Reply With Quote
Old 02-26-2002, 08:28 AM   #2
live311
Member#: 10801
2008 Outback
None of them are really worth it. You certainly don't need to use them as often as they recommend (if it's not broken, don't fix it). But if your car is running crappy give it a try. It certainly won't make it worse. As for which one is better, I couldn't really tell you. I always went for the ones that claimed to do the most (and thus cost more). But I've never used any of that stuff on my RS.
live311 is offline   Reply With Quote
Old 02-26-2002, 09:02 AM   #3
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
Red Line Fuel Injection Cleaner- least abrasive to your fuel system components. Can be used as often as necessary.
Barry
Barry is offline   Reply With Quote
Old 02-26-2002, 11:40 AM   #4
Mike Smith
Member#: 744
00 BRP RS Coupe
When I had my Justy, the dealer recommended a bottle every third tankful. Is the RS running crappy? Well, it does have the dreaded hesitation problem between 3500-4500 RPM and it occasionally goes into the on-off mode when it comes to throttle position - cresting a hill and back off slightly to hold speed, and the throttle just shuts down completly then pops back on when I push down a little
Old 02-26-2002, 11:46 AM   #5
Mike Smith
Member#: 744
00 BRP RS Coupe
Old 02-28-2002, 10:35 AM   #6
Kyle Paton
Member#: 1184
2012 Impreza
Dark Grey Metallic
Redline works the best. I even use it in my sports bike.
Kyle
Kyle Paton is offline   Reply With Quote
Old 02-28-2002, 12:58 PM   #7
RRinDC
Member#: 204
1998 Impreza OBS
Glacier White/Slate
Talking Chevron Techron...
...works for me.
RRinDC is offline   Reply With Quote
Old 02-28-2002, 01:51 PM   #8
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I was told to stay off any fuel additives except during the winter, I add dry gas once every once a while.
tmat3 is offline   Reply With Quote
Old 02-28-2002, 01:54 PM   #9
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Wait, you wrote,
You get that too? I sometimes get a feeling like the red line limiter kicked in around 2000RPM on 2nd/3rd gear. Or, more like fuel filter got clogged up. But, if I let go the gas and step on it again, it goes away instantly. Like I said, put some dry gas in it and see what happens. You may have moisture in the gas line.
Old 03-03-2002, 12:21 PM   #10
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
I've always used Red Line, or Chevron Techron at every oil change. Done this with the past 5 cars (20 years,) and never had fuel system problems.
Jim's .02
MackDaddy is offline   Reply With Quote
Old 03-22-2002, 06:13 PM   #11
Redleader
Member#: 14430
'02 WRX Wagon WRB
STi swap luvin it!!!
Smile
In my other hoopdy(Chevy Tubro Sprint) with 157,000 miles I've always used Chevron Techron gas and additive with no probs.
Redleader
Redleader is offline   Reply With Quote
Old 03-23-2002, 12:14 AM   #12
Jademonkey
Member#: 9213
2000 RS
Red
Another vote for Redline! ~$5 at Pepboys.
Jademonkey is offline   Reply With Quote
Old 03-23-2002, 05:51 PM   #13
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Chevron Techron.
ColinL is offline   Reply With Quote
Old 03-25-2002, 10:04 AM   #14
alfaguy
Member#: 14238
2002 WRX Wagon - PSM
Alfas: 89 Milano | 72 GTV
I corresponded with a former Chevron engineer on this topic, his recommendation was to use Techron twice a year, and never more than 2 bottles per oil change as this can cause the oil to become diluted.
alfaguy is offline   Reply With Quote
Old 03-25-2002, 11:16 AM   #15
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Berryman Chemtool
I've had great results with Barryman Chemtool B-12. Get the one sold in metal cans -- it's the strongest. It is usually available for under $2.50 at Walmart/K-Mart, PepBoys, etc.
You may want to try cleaning your throttle body. Gunk from the PCV system often accumulates on the bottom of it, causing idle problems, etc. Take off your air box (the one closest to the throttle body) and spray some carb/intake cleaner in there. Wipe thoroughly with a clean rag. Move the throttle plate out of the way with one hand and try to reach as deep as possible with the other while cleaning. Then spray some more carb/intake cleaner in there, applying as much pressure as possible. Assemble the air intake and start the car. Bring it up to about 2k rpm. It may run rough for a while and may blow some black smoke out back. This is normal, part of the cleaning process.
A good carb cleaner is, again, Berryman Carb Cleaner with B-12. Cheap and very effective. They also make a dedicated intake cleaner but I've never seen it in stores.
http://www.berrymanproducts.com/
vvk is offline   Reply With Quote
Fuel additive & turboxs stage 2, more prone to knock? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-03-2002 05:51 AM
Fuel Additives (eg. Octane Boost) Torch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-30-2002 11:31 PM
fuel additive question IggDawg Normally Aspirated Powertrain 6 12-12-2001 07:37 PM
Fuel additives zensvx SVX Forum Archive 2 07-03-2000 01:58 PM
Fuel additives +/- John2.5RS General Forum Archive 2 05-28-2000 06:10 PM
