Old 05-21-2008, 08:09 PM   #1
phate1229
Member#: 173615
2015 WRX Limited
Default maddad boost gauge
I've been installing the boost gauge and have run into a snag, on the bpv line where it says to cut and then put the T adapter in, the line on my 06 sti is too big for the T adapter, where can I get another T adapter or where else should I tap to fix this?
phate1229 is offline   Reply With Quote
Old 05-22-2008, 02:08 PM   #2
FFKnuckles
Member#: 132116
2004 WRX
You should be able to find a T adapter in all shapes and sizes at a local auto parts store such as Pep Boys and Autozone down there.
If you're not familiar with Salisbury, the Rt. 13 (business) Pep Boys by the mall should have what you need. And if you don't have another car or can't get someone to drive you, tape it up I guess...it just may run like **** for a little bit, but everywhere in Salisbury is only like 5 miles end-to-end or so.
FFKnuckles is offline   Reply With Quote
Old 05-24-2008, 01:10 PM   #3
rmarceau
Member#: 119018
2004 WRX STi
I had the same problem on mine. The BPV line seems to taper at the end; when I cut it, the provided T-connector was too small to fit mid tube. I did what FFknuckles said and picked up a set different sized T-connectors and adapters to make it work.
Don't forget to plug in the callibration button like the directions say. I didn't do it right the first time and was reading high until i calibrated the gauge correctly.
Enjoy the gauges, they look better than Defis and are much less expensive!
rmarceau is offline   Reply With Quote
Maddad Boost Gauge Installation Help! All4bSpinnin Electrical & Lighting 11 06-11-2009 03:51 PM
is this normal ??? how accurate is maddad boost gauge boostedsti06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 12-26-2007 09:33 PM
Maddad Boost Gauge (60mm amber) All4bSpinnin Car Part Reviews 8 12-08-2007 09:08 PM
Problem with Maddad boost gauge Meister Electrical & Lighting 9 11-11-2006 11:05 AM
Maddad boost gauge question BRADLEY03 Electrical & Lighting 2 09-18-2006 03:41 PM
