Old 05-23-2008, 12:20 AM   #1
jfdavis22885
Member#: 145716
08 Lexus IS 350
05 WRB WRX Stg2 (Sold)
Default Window squeak
anyone ever had their window squeak real loud right when your raising it and its about fully up. I took apart the whole door today, lubricated the joints in the window assembly. and it worked fine. Put it all back together and shut the door and its doing it again...WTF anyone else have this anoying problem
jfdavis22885 is offline   Reply With Quote
Old 05-23-2008, 12:23 AM   #2
dethstar764
Member#: 139868
2006 WRX
obp black
mine squeaks when i raise it up all the way
dethstar764 is offline   Reply With Quote
Old 05-23-2008, 12:44 AM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
It's where it meets the insulation in the door frame. I've fixed it by readjusting the insulation, or if you have the door apart make sure the window is mounted solid, not loosening. If it shifts it could do that.
I feel your pain, it's frickin annoying
Audiosavvy is offline   Reply With Quote
Old 05-23-2008, 12:26 PM   #4
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Yea its probably the friction of the smooth glass against the resilient rubber insulation or weather stripping... if you have a light lube or oil or even a touch of tire shine on a rag or something that should do the trick. Try readjusting the strip or applying just a tad to the rubber, not the glass. Not very scientific though, haha, but good luck.
JavaBot is offline   Reply With Quote
Old 05-23-2008, 01:37 PM   #5
bluesubie
Member#: 767
04 FXT
I'm lazy, so I had the dealer (Flemington) work on mine twice when I was under the 3/36 warranty.
-Dennis
Old 05-24-2008, 12:12 PM   #6
nardvark
Member#: 145108
2002 Impreza TS
-Dennis
Off-topic, but how is Flemington? I'm about halfway between them and Nitti's in Hamilton, and wondering who'd be better for something like a timing belt change.
nardvark is offline   Reply With Quote
Old 05-26-2008, 12:15 PM   #7
bluesubie
Member#: 767
04 FXT
Search the tri-state forum for a lot of great comments. Here's a story in Drive about their head tech. They work on all three of my Subes.
-Dennis
Old 05-26-2008, 02:58 PM   #8
jfdavis22885
Member#: 145716
08 Lexus IS 350
thanks for the responses, im glad to see im not the only one who cringes when i raise my window
Old 05-26-2008, 04:34 PM   #9
steverx05
Member#: 128269
My driver's side window squeaks like crazy when I lower it. I've tried some lubrication on different parts inside the door but it hasn't helped much. I think I've gotten used to it though and I laugh when the loud squeaking freaks out my passengers.
steverx05 is offline   Reply With Quote
Old 08-21-2009, 11:42 PM   #10
kptimpreza
Member#: 140700
2007 2.5i wagon
satin white pearl
its not the seals its in the door and gets worse when its hot. if you hold the door open and put pressure on the window pushing outward and roll up the window you can hear it
kptimpreza is offline   Reply With Quote
Anyone fix the window squeak on their own? beastcivic General Community 3 07-16-2002 05:04 PM
Window Squeaks OSUWrx Newbies & FAQs 3 05-16-2002 09:58 PM
Driver side window squeak? KAuss Bay Area Impreza Club Forum -- BAIC 10 05-08-2002 03:02 PM
