Old 05-23-2008, 01:31 AM   #1
Pick9811
Member#: 175050
2006 Impreza WRX STi
Question Please help with my Defi EGT install!
I am trying to install my Defi EGT gauge sensor. I need to know where to put it. I am hoping these are pictures of the appropriate place to insert that sensor... just tell me if I am right.
The big red arrows are pointing at my guess:
http://i304.photobucket.com/albums/n...nsorpoint1.jpg
http://i304.photobucket.com/albums/n...nsorpoint2.jpg
If not, where does it go? If I am right, how hard is it going to be to get this bolt loose?
Thanks,
Pick
Pick9811 is offline   Reply With Quote
Old 05-23-2008, 01:38 AM   #2
victor.q.tang
Member#: 113777
2000 miata
usually tapped into driver side exhaust manifold.
victor.q.tang is offline   Reply With Quote
Old 05-23-2008, 09:09 AM   #3
Pick9811
Member#: 175050
So, I should drill and tap my own hole? What is this thing for, if not for an EGT sensor? It's just a random bolt sticking out of the downpipe I guess?
Old 05-23-2008, 09:16 AM   #4
MIKE DD
Member#: 106818
2003 Truck
i'm thinking you bought your car used? Looks like someone may have had an egt or wideband tapped there, mine had one as well when i bought it. Regardless, search for the install instructions, you'll need to tap a hole in your manifold. You are going to find lots of different ways to do this, pick one you are most comortable with.
MIKE DD is offline   Reply With Quote
Old 05-23-2008, 10:07 AM   #5
Pick9811
Member#: 175050
I did buy my car used, and the guy put a lot of aftermarket parts on it. So, I am unsure of a lot of things assosciated with the car, that's why I am asking a lot of questions on here.
This car does have headers on it. Does that change install location? I am going to look at it right now. If anyone has any advice please let me know. I am sure I'll be back on in a few minutes with more questions since nothing on my car is stock.
Thanks,
Pick
Old 05-23-2008, 10:22 AM   #6
MIKE DD
Member#: 106818
2003 Truck
nope, that won't change the install location.
Old 05-23-2008, 10:29 AM   #7
Pick9811
Member#: 175050
the headers bolt on right at the block. The thick cast manifold is gone, and has been replaced with header. I am supposed to drill and tap the header? It is maybe a little thicker than normal exhaust piping, will it hold?
Pick
Old 05-23-2008, 10:43 AM   #8
MIKE DD
Member#: 106818
2003 Truck
have you tried searching yet? lots of install instructions around, it's pretty straight forward.
Old 05-23-2008, 03:10 PM   #9
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
With headers you are going to have to drill a hole near the collector for the drivers side bank and then have a bung welded on that accepts the EGT probe that came with your gauge.
The pipe thickness will not support tapping and there will not be enough thickness to keep the probe from blowing out almost immediately.
This thread
http://forums.nasioc.com/forums/show....php?t=1036365
Is a great tutorial for installing Defi's,a nd if you scroll down towards the bottom it illustrates the EGT installation but on a stock manifold.
Read through the Unibomber FAQ for gauges and you will find a lot of good information about most gauges.
Also those pictures you posted are where you want to mount your wideband 02 sensor, not your EGT.
By the time your exhaust gasses hit that spot, they have cooled enough to make your expensive EGT gauge useless as I am told.
The proper spot for EGT probe is as close to the exhaust port as is feasible.
Team Scream is offline   Reply With Quote
Old 05-24-2008, 07:09 PM   #10
Pick9811
Member#: 175050
Question Necessary?
I know you said it was necessary to have a bung welded on. That was my take at first, but I contacted the manufacturer of the headers (GTSpec) and asked them. They said just drill and tap, apparently "it's done all the time". Any comments or concerns? I think I may try it, and then if it's bad, I'll have the bung welded on that spot.
Thanks again,
Pick
Please Help With Oem Underseat Sub Install dan1587wrx Car Audio, Video & Security 9 06-08-2007 05:52 PM
Please Help on my Catch Can Install ColesSTi Newbies & FAQs 7 10-27-2006 01:12 PM
Help with my Defi gauges in 06 TR UndertoW101 Newbies & FAQs 7 04-21-2006 07:29 AM
Please help with reverse glow gauge install on 03 WRX cky211 Interior & Exterior Modification 18 01-15-2004 04:52 PM
Please help with MY98 keyless entry install mattjb Car Audio, Video & Security 1 03-08-2002 11:31 PM
