Old 05-23-2008, 09:24 PM   #1
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Default ScanGauge II XGauge Commands that work with Subarus
Anyone have any luck knowing what XGauge commands work reliably with Subaru's? So far I have the Horsepower working, but when at full load it thinks my 173HP of N/A Fury is a 1000HP beast.
Any others like Tranny Temp, Coolant temp or any other interesting ones work?
Or does anyone know where I would be able to find out how to determine what codes refer to what on the Subaru ECU's?
Here is a PDF of the various XGauge possibilities with other cars, I have only just started experimenting with what works and what doesn't.
http://scangauge.com/support/pdfs/XGAUGE.pdf
MConte05 is offline   Reply With Quote
Old 07-31-2008, 08:54 AM   #2
bguthro
Member#: 185817
Default XGuage?
I just got my SG2 on my 05 WRX -& I thought I'd bump this thread up...
I was just wondering if you ever got any other XGauge commands working?
bguthro is offline   Reply With Quote
Old 08-03-2008, 01:15 AM   #3
jbleee
Member#: 72366
2004 Forester X - MT
Gold
bump too... i just have hp entered in as well
jbleee is offline   Reply With Quote
Old 09-19-2008, 03:36 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
nobody else? HP works on my wrx, I've seen 240 hp momentarily. it is somewhat sporadic though for peak HP because it samples and averages, even on the highest rate setting. Interesting to watch the dip in HP at idle from the AC though, mine usually goes from around 8hp at idle to 6.8 or so with it turned on.
Old 10-03-2008, 11:32 AM   #5
20BlueWRX02
Member#: 156673
2007 Impreza 2.5i
CGM
I just got one of these and I'm going to be playing around with it as well... I don't think it's a big hit with the subaru community which is why nobody really talks about it. But I'll be playing around with it to see what other gauges I get working.
20BlueWRX02 is offline   Reply With Quote
Old 11-10-2008, 09:21 AM   #6
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
bump to find out how to get MPG to work. I just installed mine and went for a quick drive, and all it would tell me for MPG was 0.0 and then 999999999.
H-Dtech is offline   Reply With Quote
Old 11-10-2008, 11:01 AM   #7
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
I didn't have to do anything special to get MPG to work. It wasn't very accurate until I calibrated it over a few fill ups, but I got readings right away.
Do you ever get anything but 0.0 and 9999? Mine reads 0.0 when I'm not moving, naturually. And it reads 9999 when I'm coasting in gear -- the injectors shut down, so I'm getting effectively infinite mileage.
DrSaabaru is offline   Reply With Quote
Old 11-10-2008, 11:50 AM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Don't you need to enter the number of cylinders, tank size, Type of fuel...
wrxdrvr is offline   Reply With Quote
Old 11-10-2008, 12:33 PM   #9
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
I entered my engine size, tank size, and type of fuel, but have gotten nothing but 0.0 and 999..., I did some other work to the car and took it for another drive and It wouldn't read my ign timing, engine load, or MAP this time, where it was earlier. I'm wondering if I have the sampling rate up too high, because I know from what I have read that the MPG calculates every 2 sec. and right now I have it set to refresh as fast as possible.
Old 11-10-2008, 01:17 PM   #10
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would unplug it and let it go through it's set up again using the default to its factory setting and use medium or slow scan rate.
Old 11-10-2008, 03:59 PM   #11
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
well I lowered the sample rate as low as it would go, and went for a longer drive and everything was giving me a reading including mpg. so on the way back I stopped and raised the sample rate to normal and everything was still working for the rest of the trip, so I guess It just took alittle while for it to get enough info for it to give me a reading.
Old 11-12-2008, 08:09 AM   #12
20BlueWRX02
Member#: 156673
2007 Impreza 2.5i
CGM
Does anyone else have a problem with their scangaugeII reseting itself after heavy acceleration and max boost?
It seems like when I get on it, everything resets to zero and I get some crazy good gas mileage. Like it shows over 5000 miles until my tank is empty??
Old 11-12-2008, 10:30 AM   #13
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Mine shuts off sometimes when I keep it on the fast sample rate, but works well on the slow sample rate,
Old 11-14-2008, 09:25 AM   #14
20BlueWRX02
Member#: 156673
2007 Impreza 2.5i
CGM
Thanks for that advice... I'll try it today. It's really frustrating!
Old 11-20-2008, 05:18 PM   #15
maglite
Member#: 194477
2005 Outback Sport
Grey
There's instant MPG, which I believe is the default one and the one you've been looking at... but there's also various X-Gauge MPG values that can be created for averages of MPG, speed, etc, for "current", "day", "tank", etc...
Read the manual, it takes a bit of brain work to figure it out at first, but once you get it you'll realize it's pretty simple
I leave mine in my Chevy so I can also view stuff like the ATF temp... the MPG averaged for the "tank" is fairly accurate vs. calculating based on mileage and gallons at next fill-up using your gas slip ...
SLIP -|- SCAN GAUGE
19.1 -|- 17.8
20.1
-|- 20.5
18.0
-|- 18.4
19.5
-|- 19.3
18.5
-|- 15.6
20.0
-|- 21.3
19.7
-|- 20.6
19.3
-|- 17.7
19.5
-|- 20.3
23.7
-|- 22.1
22.3
-|- 23.9
21.0
-|- 21.0
20.2
-|- 18.6
18.5
-|- 18.5
18.7
-|- 18.7
17.1
-|- 17.5
19.3
-|- 19.2
(there might be a couple of odd-balls in there if I had the scan-gauge disconnected for a period on that particular tank...)
maglite is offline   Reply With Quote
Old 08-16-2010, 08:58 AM   #16
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Sorry for bumping such an old posting, but I found something neat. If your scangauge supports the X Gauge feature, you can have a boost gauge:
There's no longer any need to "do the math" in using MAP readings to determine boost as someone has come up with an XGauge to do it:
* To start, from the HOME screen use MORE>MORE>MORE>XGAUGE
* Then in the top right select the number of the XGauge memory you want to use (0 to 24)
* Next press <EDIT which takes you to the TXD screen
* Using the buttons next to + and - to select characters and the -> in the top right to move to the next character:
o Enter 686AF1010B on the TXD screen and press OK>
o Enter 0441850B0000 on the RXF screen and press OK>
o Enter 2808 on the RXD screen and press OK>
o Enter 00910064#### on the MTH screen and press OK>
#### PSI
FF8A 11.8
FF89 11.9
FF88 12.0
FF87 12.1
FF86 12.2
FF85 12.3
FF84 12.4
FF83 12.5
FF82 12.6
FF81 12.7
FF80 12.8
FF7F 12.9
FF7E 13.0
FF7D 13.1
FF7C 13.2
FF7B 13.3
FF7A 13.4
FF79 13.5
FF78 13.6
FF77 13.7
FF76 13.8
FF75 13.9
FF74 14.0
FF73 14.1
FF72 14.2
FF71 14.3
FF70 14.4
FF6F 14.5
FF6E 14.6
FF6D 14.7
FF6C 14.8
FF6B 14.9
FF6A 15.0
NOTE: Atmospheric Pressure: 6,000 ft above to 500 ft below sea level
jonklein611 is offline   Reply With Quote
Old 12-14-2010, 12:44 AM   #17
Bimmer
Member#: 4116
2002 Impreza TS
Can ANYbody point me to the codes to access ATF temp in our Subarus?
Bimmer is offline   Reply With Quote
Old 12-14-2010, 07:13 AM   #18
jonklein611
Member#: 117776
WR Blue Pearl
We don't have the codes, email the manufacturer and see what they say, they were extremely helpful for my questions.
Old 12-14-2010, 02:03 PM   #19
Built Industries
Member#: 33839
I will have to check and verify, but i have the codes for the scangauge X that tell you fuel trims.. Come in nice while tuning your maf
Built Industries is offline   Reply With Quote
Old 01-04-2011, 04:43 PM   #20
Nickcrsx
Member#: 196071
Bump for more info
Nickcrsx is offline   Reply With Quote
Old 01-05-2011, 03:47 PM   #21
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
^^ Yes you can do any of the fuel trim banks. Long term and short term. I have also successfully done horsepower (far from accurate) and MPG (also not accurate). I have tried fuel level but it doesnt work.
evan_impreza is offline   Reply With Quote
Old 01-05-2011, 03:59 PM   #22
jonklein611
Member#: 117776
WR Blue Pearl
MPG works well, assuming you do full fillups and calibrate it every fuel up.
Old 01-06-2011, 08:32 AM   #23
NotJayKay
Member#: 265729
2005 Saab 9-2x Aero
#### PSI
What is supposed to be entered in the #### section, I'm assuming the characters to the left of the PSI?
NotJayKay is offline   Reply With Quote
Old 01-10-2011, 08:06 PM   #24
Bimmer
Member#: 4116
2002 Impreza TS
I don't understand the info in posts #15 and 16, but this worked for me for boost:
Boost in PSI - 686AF1010B - 0441850B0000 - 2808 - 00910064FF71
Boost in BAR - 686AF1010B - 0441850B0000 - 2808 - 000A0064FFF6
This is from the Forester forum. I'm using the PSI gauge, I have to have MAP displayed to make it work, but it matches the readings on my Greddy gauge just about perfectly.
Bimmer
Old 01-18-2011, 07:19 PM   #25
krinkle
Member#: 264311
2011 Impreza WRX STi
white
I just pulled the ScanGauge II out of my 98 Civic EX and put it in my 2011 STi (1 day old!)
That worked but I too have to have MAP displayed for it work. I'm going to e-mail Linear Logic and see if there is a way to get boost with out having MAP displayed. I'd also like to see the AF Ratio, but I tried this:
Air To Fuel Ratio 1 - C233F10124 - 04410524 - 2808 - 05B900800000 – AF1 - Ratio
With no luck.
Here is the list I got off the Forester board:
SCANGAUGE ii - XGAUGE codes for Subaru Vehicles
====GAUGE============TXD=======RXF=====RXD======MA TH====NAME===UNITS=====
1. HorsePower - 00 - 400080000000 - 0000 – 000A00170000 - HPR - HP
2. TurboBoost in PSI - 686AF1010B - 0441850B0000 - 2808 - 00910064FF71 – BST - psi
3. TurboBoost in BAR - 686AF1010B - 0441850B0000 - 2808 - 000A0064FFF6 – BAR - bar
4. Manifold Air Flow g/s - 686AF10110 - 044145100000 - 2810 – 000100010000 – MAF - g/s
5. Open/Closed Loop - 686AF10103 - 044105038000 - 2808 - 000100010000 – OCL – hex*
*1:= Open, not yet warm 2:= Closed, normal 4:= Open, due to high load 8:= Open, system failure 10:= Closed, but something's wrong
6. Short Term Fuel Trim - C233F10106 - 04410506 - 2808 - 00C80100FF9C - SF1 - +/-0-99
7. Long Term Fuel Trim - C233F10107 - 04410507 - 2808 - 00C80100FF9C - LF1 - +/-0-99
8. 02 Sensor values - C233F10115 - 04410515 - 2808 - 000100020000 - O21 - 0to99
9. Air To Fuel Ratio 1 - C233F10124 - 04410524 - 2808 - 05B900800000 – AF1 - Ratio
10. Air To Fuel Ratio 2 - C233F10134 - 04410534 - 2808 - 05B900800000 – AF2 - Ratio
11. Lamda 1 - C233F10124 - 04410524 - 2808 - 006400800000 – LA1 – 0.8 – 1.2
12. Lamda 2 - C233F10134 - 04410534 - 2808 - 006400800000 – LA2 – 0.8 –1.2
13. Coolant Temp - 686AF10105 - 03104410505 - 2808 – 00090005FFD8 – FWT – oF
krinkle is offline   Reply With Quote
DIY MY02 fog light cover bracket that work with fog lights installed Darren_2.5RS Mid West Subaru Owners Club Forum -- MWSOC 1 04-23-2014 01:09 AM
Any BBKs that work with 17x9 Work CR-Kai? akdmx Brakes, Steering & Suspension 1 03-27-2010 12:50 AM
O2 XDA Mini II PDA phone. GSM, works with AT&T, Cingular, and mattjk SCIC Private Classifieds 6 12-17-2008 01:01 PM
Is there a Bolt-in rollcage that works with the sunroof? N/A01RS Motorsports 3 08-12-2002 01:35 PM
Looking For Performanc Shops That Work On Subarus In The Mid Uthinkso Normally Aspirated with bolt-on Forced Induction Powertrain 1 11-15-2001 01:02 AM
