Old 05-25-2008, 01:27 AM   #1
jonace1
Member#: 145916
2007 Impreza STi
Default 07 STi Pushbutton Start w/no key cylinder
I've always loved the idea of pushbutton starters, and always wanted to put one in my old cars. The problem was that all of the aftermarket ones I saw homemade still used the key (with good reason I suppose, someone could just take it without a key). So I couldn't do that, until I got a car with an Immobilizer piece.
Now I had that blank AUX in space after I put my deck in, so I could resist making a little push button starter for that space.
Basically (and I could write up a walkthrough if anyone wants it) I pulled out the ignition cylinder, Wired up relays for the ignition, accessory, starter, and keysense. I hooked the relays up to a switch and button for starting and power.
Then I extended the key ring, key sense, and immobilizer wires, and cut a small hole in the cupholder. put the key ring up through it, put in some foam in it for a nice little inside. Now you can put the keys in the cupholder to start it, move them if you need it once it starts, and it still holds cups.
Pictures say more than the words I guess, take a look:
Now I just have to figure out what to do with that gaping hole in the column...
jonace1 is offline   Reply With Quote
Old 05-25-2008, 02:36 AM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
haha better do something with the hole before a cop pulls you over and thinks you stole the car
cool idea
jdubya301 is offline   Reply With Quote
Old 05-25-2008, 02:42 AM   #3
06OutbackSport
Member#: 160318
2006 Outback Sport
I like the idea. It reminds me of my old Saab. It had the ignition down by the shifter. I loved it!
06OutbackSport is offline   Reply With Quote
Old 05-25-2008, 11:27 AM   #4
Crawdads
Member#: 30907
SWP GDB-G
The JDM 08s have what looks to be a rubber or plastic filler piece for the ignition cylinder hole (for the cars with push button start)
You could see if somebody could source you one.
Crawdads is offline   Reply With Quote
Old 05-27-2008, 04:38 PM   #5
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
jamie @ subaru genuine parts ought to be able to, she is the best!
ProdriveDreams is offline   Reply With Quote
Old 05-27-2008, 07:12 PM   #6
Biznatch231
Member#: 170676
2005 Forester XT
Do you have a wiring diagram? Mainly the relays and how you wired them up. I'm about to do a remote start/alarm install along with a carputer while I have the dash/center consol out so I might just add something like this to my list
Biznatch231 is offline   Reply With Quote
Old 10-18-2008, 05:50 PM   #7
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
^^ yea that would be cool if you could provide how the relays are wired up. I always wished that I had a push button start without the key like in newer cars.
toutanje is offline   Reply With Quote
Old 10-20-2008, 12:32 AM   #8
Fail Wagon
Member#: 133584
put a gauge there. haha
Fail Wagon is offline   Reply With Quote
Old 10-20-2008, 03:00 AM   #9
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
So, I take it the switch turns the car to "ignition-on" then you push the button to engage the starter...
but what about the accessory part of the switch?
What I mean is, originally, you:
1. Put key in
2. Turn once for accessories
3. Turn again for ignition
4. Turn finally to engage starter (then it goes back to 3)
What do you do for step 2?
BeBop86 is offline   Reply With Quote
Old 01-15-2009, 10:48 PM   #10
STi scene
Member#: 183949
05 STi
Black and Gold
bump for bebop86's guestion, and how for away can the end of the key be away from the cylinder with it still working?
STi scene is offline   Reply With Quote
07 STI Wont Start! HELPP!!!! teamsti Open Source Reflashes 14 02-06-2009 09:16 AM
07 sti can't start fujiwara_yingyu Electrical & Lighting 2 10-26-2007 05:19 PM
07 sti can't start fujiwara_yingyu Vancouver Impreza Club Forum -- VIC 16 10-26-2007 05:09 AM
07 STi, catless downpipe 19psi, no EM, no overboost? OMG_WTF Newbies & FAQs 3 08-31-2007 09:56 PM
06-07 Sti NEEDS CATTED downpipe? no Upipe? DRK REX Pre-2002 Factory Turbo Powertrain 3 02-05-2007 02:37 AM
