Old 05-25-2008, 09:23 AM   #1
SlouWRX
Member#: 145155
Have a Nice Day? HELP gauges don't turn OFF.
I wired 2 prosport gauges to my clock harness to test the colors and what not, everything was fine exept the gauges will not turn off when I turn the car off.
The gauges are not connected to the sensors (boost and OP sensor) they are ONLY connected to the harness of the clock pod.
What am I doing wrong? plz help thnx.
SlouWRX is offline   Reply With Quote
Old 05-25-2008, 09:44 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You obviously connected the gauge power to constant 12V instead of the correct accessory/switched 12V. It's easy enough to check the wires with a meter to find which is which, if you don't have a wiring diagram.
Old 05-26-2008, 10:50 PM   #3
j1168osh
Member#: 105609
2002 wrx
psm
When you turn on your car if set right the clock will be on the right time. This is because the clock has a thing called the memory wire which has constant power so you dont have to set your clock every time you turn the car on. There is also a wire to the clock that powers the clock face or the read out THE NUMBERS. This comes on when you turn the key on. A better place to get power for the gauges in under your steering column at your ignition but you should buy or barrow a volt ready and see what wire losses power when you turn the car off and gets power when you turn it on. This will fix your problem.
j1168osh is offline   Reply With Quote
Old 05-27-2008, 04:05 AM   #4
mechguy
Member#: 173749
Check gauges is different than check engine. You are going to have to diagnose what system your gauges monitor isn't functioning properly to turn it off. Alternator, Oil pressure, coolant temp, something isn't working properly. I donít know if this will work on you but try to pull the cluster out and test look at the back side for wear or damages check good and test before replace. Hope its helps.
______________________________
My blog "autopartswarehouse blog"
mechguy is offline   Reply With Quote
Old 05-28-2008, 07:31 PM   #5
j1168osh
Member#: 105609
2002 wrx
psm
I dont think you understand his ? do you ^^^^^^^^^^^^^^^^^^
Old 05-28-2008, 07:35 PM   #6
theshadowonme
Member#: 168096
2002 WRX Wagon
I bet that's it. If you look on your clock pod, they are labeled just find which color is the 12v accesory and rehook them up. I made that mistake too, it's an honest one to make.
theshadowonme is offline   Reply With Quote
HELP ASAP!! Error says don't turn off ignition tabrad Open Source Reflashes 4 05-29-2008 06:52 PM
Gauge doesn't turn off? gummy Newbies & FAQs 4 08-19-2006 11:34 PM
I swear to God, if you don't turn off this Michael McDonald DVD... soldmyboxster Off-Topic 3 05-02-2006 05:47 AM
Parking lights don't turn off leelaw Service & Maintenance 5 03-22-2005 07:37 PM
STi HID lights don't turn off??? dookiebob Interior & Exterior Modification 3 01-28-2003 09:09 PM
