Notices
Old 05-25-2008, 11:57 PM   #1
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
Default AC always on by itself
so,, my AC is always on, but the AC button light isn't on though.
what to check?
this started to happen since the last time, when I was trying to install the headunit, and somehow, it it stuck inside while i was trying to pull it out, i pulled so hard, and one of the electric wire behind the HVAC control got ripped, it didn't come off, but the wire skin was off, so I use electrical tape to tape it back. I think most likely that I messed up the wire right behind the AC switch or I killed the AC switch??
this is killing my mileage by 30miles less per tank.. now i just drive without any air venting a bit window down...
qualityracer is offline   Reply With Quote
Old 05-26-2008, 10:33 AM   #2
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
.. Just to be sure, you aren't using the windshield defroster, are you? It automatically runs the A/C.
Old 05-26-2008, 11:47 AM   #3
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
yep, I always use that, but the AC light isn't on though.... is that the case?
Old 05-26-2008, 11:54 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes in defrost mode the compressor will always run, and the AC light will not illuminate.
Old 05-26-2008, 12:03 PM   #5
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
ahhhuhhhh, finally... lol Thanks.
Old 07-03-2008, 04:28 PM   #6
landry1
Member#: 159595
04 WRX
JBP
now the question is how can you make the a/c not turn on with defroster????i dont want my ac running when i use the heater in the winter??
landry1 is offline   Reply With Quote
Old 07-03-2008, 09:41 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
you actually do want it running... it serves 2 purposes, it keeps the compressor lubed and and also defrosts your windows. (warm moist air does a great job of fogging up windows when you really want to defrost them!)
but yes, it is fairly easy to disable, there is a micro switch you have to move in the controls.
Old 07-05-2008, 12:03 AM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
+1, you want dry air to remove fog from your windscreen.
jdubya301 is offline   Reply With Quote
Impreza Turns on by itself Jutboy Electrical & Lighting 16 01-10-2010 12:33 PM
seat reclining by itself on bumps Bluefoton Interior & Exterior Modification 8 07-20-2009 08:57 PM
Computer keeps turning on by itself. EGY5 Off-Topic 29 01-21-2008 12:24 PM
Boost dropped to .6ATM by itself on a hot day? powerlabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-13-2005 09:01 PM
peugeot engine shuts off and turns on by itself Smart_alek Off-Topic 14 09-08-2004 05:53 AM
