Old 05-26-2008, 06:28 AM   #1
redsunsfd
Member#: 165189
1997 GF8 WRX
Default Turbo Timer install problems :(
I hope this is the right place to post this.
Finally got around to installing my HKS Type-1 timer in my 97 GF8. I used the FT-2 harness so the installation was a breeze and since I don't have access to a soldering iron (or the skills) I used the three vampire taps that were included to tap the E-brake wire, and the I and S wires going to the ECU. Well, I reconnected the negative terminal to the battery and the timer doesn't even light up. I don't have a voltimeter and if I did I guess I'd have to strip some of the wire to get a reading right? So I'm a little confused as to why it won't even light up after turning on the car. Even if I didn't connect the E-brake or ECU wires, as long as it's connected to the harness it should still get power, right?
Everything is new out of the box, too.
Sorry if I overlooked any vital install info, any help would be greatly appreciated.
Thank you.
redsunsfd is offline   Reply With Quote
Old 05-27-2008, 06:34 PM   #2
redsunsfd
Member#: 165189
1997 GF8 WRX
Sorry to bump, but any ideas?
HKS Turbo Timer instalation problems fractur3 Interior & Exterior Modification 3 06-21-2007 11:49 AM
Turbo Timer/Alarm problem stilesg57 Electrical & Lighting 7 03-25-2003 01:04 AM
blitz turbo timer installation problem fanatyk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-30-2002 08:32 PM
Turbo Timer Install w/upgraded alarm - Problems PapaG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-29-2001 09:51 PM
Turbo Timer installer in Seattle RA North West Impreza Club Forum -- NWIC 0 01-01-2001 10:50 PM
