Old 05-26-2008, 10:30 PM   #1
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
Default Defi gauge stuck at 19 PSI
I have a Defi BF Imperial Oil pressure gauge. It worked fine right after I installed it but after an hour or so I turned on the car and it was stuck right at 19 PSI. I've tried unplugging everything and it's still stuck there. The sender is plugged in. It reads 19 PSI even when the car is off and the gauge is turned on. It does the sweep just like normal but it acts like it's only receiving 19 PSI from the sensor. Any ideas?
Cyclops is offline   Reply With Quote
Stage 2 stuck at 7 psi max???? jeepwrx UTEC 1 03-13-2009 08:50 PM
FS: 2005 Legacy GT Non-Limited 280 WHP at 19 PSI Jim Ewing Private Vehicle 'For Sale' Classifieds 2 08-15-2007 10:14 PM
Outside temp gauge stuck at 56 degrees! Icepick Electrical & Lighting 5 12-19-2004 01:06 PM
Delta Dash meets Dawes at 19 PSI on MY99 std ECU/turbo/intercooler john banks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-23-2002 06:16 PM
Help: Defi Gauges Stuck stumpz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-17-2002 09:27 AM
