Old 05-27-2008, 05:48 AM   #1
RSXiMUS
Member#: 84362
2005 WRB STI
Default AC compressor and condensor fan won't come on
Need help guys, just helped my friend swap his new engine and reinstalled all the AC components. There is no refrigerant in the AC system right now, I wanna make sure everything is in working condition before we go get it recharged.
Well when I hit the AC button inside, it lights up like its working but the AC compressor doesn't engage nor does the condensor fan kick on. I checked the fuses and relays, everything is good. Everything is plugged in correctly. What else could it be? Does the AC system need to have pressure inside the system in order to kick on the compressor and condensor fan? Kinda stumped.
RSXiMUS is offline   Reply With Quote
Old 05-27-2008, 08:04 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The compressor will not run without a charge in the system. There is a low-pressure cutout that protects the compressor if the pressure drops below a set level. Have it evacuated and recharged and it should work properly as long as everything is installed correctly and there are no leaks.
Old 05-27-2008, 01:44 PM   #3
RSXiMUS
Member#: 84362
2005 WRB STI
Wow thanks Mulder, I was hoping it was that. Now does the condenser fan always come on with the AC on, or does it kick on at a certain temp like the cooling fan does. I'm sorry, I'm a newb when it comes to AC stuff.
AC compressor and lines, tensioner w/pulley, and AC belt shibby2821 Engine/Power/Exhaust 24 08-01-2010 06:15 PM
FS: A/C compressor and condensor w/lines renosfasteststi Engine/Power/Exhaust 5 10-11-2007 02:21 AM
('93-'01) radiator fans won't come on ruff Idle comp1 Impreza Forum 0 08-12-2006 10:17 PM
Fan won't come on...help! Goose013 Electrical & Lighting 3 06-30-2006 05:05 PM
fs impreza 93-01 a/c compressor and condensor turbocolin Private 'For Sale' Classifieds 6 12-06-2003 09:14 PM
