Old 05-27-2008, 06:13 PM   #1
sonycrr
Member#: 128161
2006 wrx limited
wrb
Default oem oil filter=how long can it last?
bought new oil from amsoil
https://www.amsoil.com/storefront/sso.aspx
got the 0W-30 Synthetic
web site says the oil can last atleast 17,500 under severe conditions. im not gonna let it go that long, probably 5-7k
but how will the oem oil filter hold up?
thanks for your help
sonycrr is offline   Reply With Quote
Old 05-27-2008, 06:28 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I Change the filter every 6,000km/3,800Miles and change the oil & filter every 12,000km/7,500Miles... Seems to work for my car, it now has 277,000km/173,000Miles. With never anything done to engine or transmission.
wrxdrvr is offline   Reply With Quote
Old 05-27-2008, 06:55 PM   #3
mikeythejew
Member#: 141672
Rated for the normal PM as common sense dictates.
7500 miles max for warranty purposes on an 06'.
mikeythejew is offline   Reply With Quote
Old 05-28-2008, 10:10 AM   #4
bluesubie
Member#: 767
04 FXT
What mikey said.
I have run mine to 8,000 miles because I couldn't get around to changing the oil at 7,500 miles. My Blackstone uoa was fine. Another member here, drees, consistently ran the OEM filter to 8,000 miles in his WRX.
Do a uoa with Oil Analyzers between 5-7k to find out for sure.
-Dennis
Old 05-28-2008, 06:01 PM   #5
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
I thought that if you take off the filter, oil would gush out. How are you changing your filter without changing the oil? Do you just drain it and add it back? Am I missing something?
druxboyz is offline   Reply With Quote
Old 05-28-2008, 06:27 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
No the filter is higher than the oil pan.. Wait 10 minutes after shutting engine off and you can change the filter and you only have to top off the oil for the little bit lost that was in the filter.
Old 05-28-2008, 06:37 PM   #7
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
cool info, i guess i assumed since it leaks a bit when i remove it. Good stuff.
Old 05-28-2008, 07:15 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
it doesnt matter what the oil companies say, do yourself a favor and follow Subaru's oil change interval. If you however are out of or dont care about your warranty do what you will.
Old 05-28-2008, 08:55 PM   #9
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
just changed my oil (mobil 1 5w30syn) and oil filter (fram) at 6,400 miles. Time for a wash
Old 05-29-2008, 12:18 AM   #10
sonycrr
Member#: 128161
2006 wrx limited
wrb
does any one know what subaru's oil chagne interval is? i think the manual says 7500 but I heard they changed that.
can some one confirm this please?
thanks! =D
Old 05-29-2008, 12:47 AM   #11
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Read the sticky thread titled Oil FAQ and it tells you what the oil change interval is. Sticky threads.....read them BEFORE posting.
Old 05-29-2008, 09:07 PM   #12
sonycrr
Member#: 128161
2006 wrx limited
wrb
3750 it is
Old 05-29-2008, 11:02 PM   #13
bluesubie
Member#: 767
04 FXT
Originally Posted by sonycrr View Post
3750 it is
7500.
Old 05-29-2008, 11:31 PM   #14
sonycrr
Member#: 128161
2006 wrx limited
wrb
Originally Posted by bluesubie View Post
7500.
3750
Old 05-30-2008, 12:12 AM   #15
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Sooo... I thought for a wrx, you need to change every 3750
Is that from the oil or filter?
If filter, can I do the filter change, then oil/filter?
BeBop86 is offline   Reply With Quote
Old 05-30-2008, 09:59 AM   #16
bluesubie
Member#: 767
04 FXT
It depends on the model year. All turbos from MY2008 onward do require oil and filter changes every 3,750. It's not mandatory prior to MY2008, although some dealers are making it every 3,750 for all years for consistency.
Whether or not the oil can last to 7,500 depends on many factors and a used oil analysis is a great way to see how the oil is holding up.
Whether the OP runs his oil to 500 miles or 5,000 miles, may not matter anyway. Amsoil gets into the gray area for warranty coverage because it's not "API certified" (except for the XL line).
sony - Keep track of the numbers from the Amsoil bottle in case you have to invoke the Amsoil warranty.
-Dennis
Old 05-30-2008, 10:17 AM   #17
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
-Dennis
I thought Amsoil was a great oil for our cars.
shamrock 05 is offline   Reply With Quote
Old 05-30-2008, 10:37 AM   #18
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
read your owners manual or see the stickies here...
I change mine every 3500 with no exception on my DD
I change mine every race on the rally car.
http://www.subiegal.com/subarugirlie...iper-paint.jpg
Old 05-30-2008, 11:05 AM   #19
shamrock 05
Member#: 120057
I dont think my owners manual is gonna tell me about Amsoil
Old 05-30-2008, 12:26 PM   #20
bluesubie
Member#: 767
04 FXT
Just because an oil doesn't have API certification doesn't mean that it's not good. It just means that the companies haven't spent the money to get an oil certified and/or they have higher additives than allowed under the current API ratings. Amsoil and Redline are both great oils, but are not API certified.
There are Subaru dealers that use Motul 8100 5W30, but it meets API SL (the older classification).
APPLICATIONS
AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for use in gasoline engines, diesel engines (API CF, ACEA B5) and other applications requiring SAE 0W-30, 5W-30 or 10W-30 with the following worldwide specifications:
API SM/CF, SL, SJ
ILSAC GF-4, 3
ACEA A5/B5-04
GM 4718M, 6094M
Ford WSS-M2C929-A
Honda HTO-06
Daimler Chrysler MS-6395N
VW 503.00
Service Life
AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows:
Normal Service(3) Up to 35,000 miles or one year, whichever comes first.
Severe Service(4) Up to 17,500 miles or one year, whichever comes first.
Replace AMSOIL Ea oil filter at the time of oil change up to 25,000 miles or one year, whichever comes first (other brands at standard OEM* intervals).
(1) Engines operating under modified conditions are excluded from extended drain recommendations. Examples include the use of performance computer chips; non-OEM approved exhaust, fuel or air induction systems; and the use of fuels other than those recommended for normal operation by the manufacturer.
(2) Mechanically sound engines are in good working condition and do not, for example, leak oil or consume excessive amounts, are not worn out, do not overheat, do not leak anti-freeze and have properly working emission control systems.
-Dennis
Old 05-30-2008, 12:38 PM   #21
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
wasn't talking to you smart ass.
was replying to the OP original question. oil filter. when to change
reading comprehension ownz joo.
Old 05-30-2008, 01:29 PM   #22
shamrock 05
Member#: 120057
I kid, I kid
Old 05-30-2008, 02:27 PM   #23
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I kid, I kid
good call....
Old 05-30-2008, 05:03 PM   #24
sonycrr
Member#: 128161
2006 wrx limited
wrb
-Dennis
hey i called amsoil to check about this, subaru not covering for warranty.
they tech rep. said that they would have to prove it was the oil that caused the problem. i dunno if thats true. or is it that if you do not use an api certified oil, that in it self can be used to justify a denial of a warranty claim?
ughhhh i just bought 12 bottles of this stuff. i dont want any problems.
Old 05-30-2008, 06:02 PM   #25
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Have you read your warranty statement so you know what it says? Amsoil is probably right, but it'll be your legal bill to force Subaru to cover any failure. Presuming you win, you should be able to get that bill back, unless of course your warranty forces you to use arbitration instead of a lawsuit...
Basically, if you did have a major engine failure AND the dealer decided to claim it was your fault for using Amsoil, the dealer would sit back and claim the Amsoil caused the failure, Amsoil would sit back and claim that Subaru has to prove it was the oil's fault... you see where this goes? Back to you having a big bill to force one or the other of them to pay up and/or make the repair.
Now, why you would presume the dealer would automatically know Amsoil was in the crankcase, why you would assume they'd blame the Amsoil, etc., is not clear to me. Take proper care of your car. Don't worry about stuff that's not going to become an issue OR ELSE just don't use something that might maybe perhaps cause you an issue.
bulwnkl is offline   Reply With Quote
How long can she last without a tune? purduephigam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-03-2006 03:52 PM
How long can you last mvstype Off-Topic 65 03-11-2004 04:41 PM
How long can you last....(Teh sequel) Mud Pig Off-Topic 37 06-09-2003 01:24 AM
Oil Filter - How Long? phred's RS Normally Aspirated Powertrain 14 07-03-2001 05:19 PM
How long can Impreza last? WRX-T Newbies & FAQs 3 05-29-2001 03:15 AM
