Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 05-27-2008, 07:25 PM   #1
minx1225
Member#: 89034
2015 WRX Limited
CWP
Default My car won't start after swapping parts! Need Help!
Hello all.
I've swapped parts from my car. After the swap , my car won't start.
List of parts swapped:
-VF-39 Turbo
-STi Pink injectors
-Walbro Fuel pump
-Bosal shorty DP
The ECU was reflashed to STOCK 2002 Map.
The swap was done by a Suby specialist.
I thought it was a battery but apparently , I don't think the battery is the problm. Here's reason why.
Video Clip:::
My car had low on gas. My friend think it should be the ECU. Maybe my ECU was fried when the ECU was reflshed to stock.
I think it could be the ECU but I don't wanna buy a part that's not causing any problem. If anyone could help me with this problem please!!!
I need to start my car within a week!. Thanks for any input!
minx1225 is offline   Reply With Quote
Old 05-27-2008, 07:37 PM   #2
Slow03Wrx
Member#: 180818
2006 Sti
Maybe your started is stuck?
Slow03Wrx is offline   Reply With Quote
Old 05-27-2008, 07:49 PM   #3
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
Here are my suggestions after doing this same swap 2 months ago.
1) After pulling the ignition fuse for priming did you try disconnecting the battery and resetting the ECU? That was my problem with not starting at first.
2) Did you disconnect/relocate any grounds? When I was installing the new injectors i moved the drivers side ground on the intake manifold. That caused a thousand problems including the fuel pump not cycling = no start
3) edit add - Green Connectors?
pearljam11 is offline   Reply With Quote
Old 05-27-2008, 08:36 PM   #4
doodie
Member#: 14578
2002 WRX Wagon
Sounds like battery to me too... Take a wire brush to the terminals.
doodie is offline   Reply With Quote
Old 05-27-2008, 08:37 PM   #5
darksc00by
Member#: 102140
2016 herpderp
Sounds like a bad ground for the starter. Or a bad starter.
darksc00by is offline   Reply With Quote
Old 05-27-2008, 09:43 PM   #6
Fast_Wrx62
Member#: 89139
2002 RIP Bugeye.
nope that is diff. is the battery not giving enough power, did u check the batterys voltage after u were cranking
Fast_Wrx62 is offline   Reply With Quote
Old 05-27-2008, 09:46 PM   #7
MrSlowbaru
Member#: 129231
2005 wrx
cgm
you killed the battery
MrSlowbaru is offline   Reply With Quote
Old 05-27-2008, 10:13 PM   #8
IIdiceII
Member#: 90438
def sounds like the battery...CLEAN the terminals and make sure the negative/ground has a nice good and tight connection.
my car used to do that a lot. the negative on the battery harness was bad and lose.
IIdiceII is offline   Reply With Quote
Old 05-27-2008, 10:51 PM   #9
minx1225
Member#: 89034
2015 WRX Limited
CWP
did you guys look at the end of the video where my battery is connected to the G35?
Old 05-27-2008, 10:54 PM   #10
darksc00by
Member#: 102140
2016 herpderp
I am telling you to check the starter ground.
Old 05-27-2008, 10:56 PM   #11
DemonPossessedNinja
Member#: 116610
2005 wrx vf-34
psm
I say its the battery...... I'm positive about it
DemonPossessedNinja is offline   Reply With Quote
Old 05-27-2008, 11:00 PM   #12
Hurley959
Member#: 140767
TDi Rand Lover
KTM 450SMR
x2...when we swapped darksc00bys car we ran into an identical issue. the starter is kicking but the spur gear isnt extending to make contact with the flywheel. the problem ended up being an extra ground hooked to the starter housing, which for whatever reason, caused the starter to not work properly.
the housing of the starter grounds out on the transmission case, so there's no need for a negative lead. check to make sure there isnt one hooked to the terminal next to the positive lead on the starter.
Hurley959 is offline   Reply With Quote
Old 05-27-2008, 11:01 PM   #13
Hurley959
Member#: 140767
TDi Rand Lover
KTM 450SMR
Old 05-29-2008, 09:57 AM   #14
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
what happened? I had the same prob with my swap last night?
initially, I had the ground wire that leads off from the same spot as the positive for the starter, grounded on the top bolt for the starter. no clicking, no spinning, nothing. so, i hooked the negative lead into the second terminal on the starter & I get the same sound. nothing else.
02darkRS is offline   Reply With Quote
Old 05-30-2008, 08:20 AM   #15
02darkRS
Member#: 80918
now w/ AVLS!
mine was the battery. mine was less than a year old. took it to advance auto. they tested it as bad. free replacement was put in. cranked right up. i had the exact explanation as you, sounds like a machine gun.
NEED HELP!! Car won't start after installing UTEC JordanHoudek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-18-2009 09:09 AM
help! car won't start after swap ejpowerguy Service & Maintenance 0 03-17-2009 10:37 PM
Need Help, car won't start after RA tranny was put in tmann Transmission (AT/MT) & Driveline 16 12-27-2006 07:25 AM
My car won't start need help immediately!! Chung Southern California Impreza Club Forum -- SCIC 14 06-19-2002 10:55 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-12-2001 12:35 AM
