#1451 |
Member#: 44501
South East
Vehicle:ZMax Dragway Concord, NC. See SE Forum |
There's a lot more to the Subaru drivetrain requirements than front overhang.. like length and more importantly width. Compare the hood length of a Fit to a Forester and imagine where the transmission would end up in the Fit. The EJ engines are some of the widest engines available these days (wider than most V8s) and wouldn't even fit between the struts on most compact cars.. which is also why Subaru's front suspensions are always so hampered in design... there's very little room between the strut tower and the outside of the fender to fit a good suspension and a large enough wheel and tire. There's a reason Subaru has used inline engines in all of their sub-compact cars.
#1452 |
Member#: 47998
Vehicle:2002 WRX Wagon 2008 Legacy QSM |
^ according to the legacy rumor, there is a new front suspension. i know its just rumor but if true then maybe subaru found a way around their "wide" engine which can be utilized in future cars like this coupe.
#1453 | |
Member#: 204920
![]() Quote:
#1454 | |
Member#: 73805
Pretty much the same as the above post I think,but I throw it up anyway..
#1455 |
Member#: 75071
Vehicle:'08 Red WRX 5DR Nav '08 White WRX 4DR Nav |
RWD Scion tC in Formula Drift...maybe a look into the future?
http://www.autoblog.com/2009/04/13/t...-car-unveiled/ ![]() |
#1456 | |
Member#: 56183
South East
Vehicle:03 WRX WRB |
#1457 |
Member#: 100192
Vehicle:00 Solara |
^best illustration yet
#1458 |
Member#: 190420
Vehicle:1997 Cavalier LS Black |
Someone should compile all of the illustrations and 'chops that have been made for this car during the last year or two.
#1459 | |
Member#: 204920
I do have a question though, given how heavy the Legacy chassis is, how are they going to make this car light ... and if they do make it light, why are the Legacy and Impreza not lighter? |
#1460 |
Member#: 170188
Vehicle:2008 WRX 4Dr. PP DGM |
#1461 |
Member#: 204920
It should have been possible for Toyota to release an FR tC given how it is based on the Avensis, now granted this would still use a transverse engine config via an AWD style gearbox with the front driveshafts removed, but still..
#1462 |
Member#: 43640
Vehicle:02 impreza silver |
When FHI released their March consolidated balance sheet results, they mentioned that:
The joint development of the 'sporty car' with Toyota is progressing favorably. At the present time, they are making efforts to increase power and to improve environmental characteristics. Originally a new plant was to be constructed to produce this car, but due to a decreased investment budget, an existing plant will be modified instead. |
#1463 |
Member#: 83633
RMIC
Vehicle:3 snaps in a Z formation |
If it looks like any of the above renderings it'll do very well I think.
#1464 | |
Member#: 135059
#1465 |
Member#: 123386
Vehicle:2002 WRX -Zip Tuned Too Low for NASIOC #009 |
God I hope it's built in LaFayette! That means I'd get to test it!
#1466 |
Member#: 171797
#1467 |
Member#: 119958
Vehicle:2005 Legacy GT Ltd. Garnet Red Pearl |
IF it is built in Japan, it might actually be close to JDM specifications.
It might actually come with optional HIDS, if the trim levels go high enough. It might actually come with normal bumpers, instead of huge ones, like the USDM, compared to JDM Legacys had. not to mention the hobbled options and trim lines list for BL Legacy in the US, compared to SOJ-built cars. It might actually come in World Rally Blue Pearl, which no SIA product gets. |
#1468 | |
Member#: 58669
#1469 | |
Member#: 14148
Vehicle:2006 Legacy GT Ltd 2006 Outback 3.0R VDC |
The rest of the features are really mostly because SOA leans toward the economy car side while the parent company has tried to move upscale. |
#1470 |
Member#: 114530
NESIC
Vehicle:2005 LGT 6MT wagon |
Actually there is a lot to it where it is built. For example bunch of interior upgrades (upgraded console, rear passenger A/C vents) during mid-cycle refresh to Legacy in 2006 where omitted in the USDM - probably due to the changes that would be required with USDM suppliers. While engines and drivetrain parts are mostly imported from Japan, sheet metal and good chunk of interior/exterior trim parts is made in the U.S/Mexico.
#1471 | |
Member#: 100117
VIC
Vehicle:2002 Impreza 2.5TS Subie Heaven |
#1472 | |
Member#: 75146
NWIC
Vehicle:1998 Impreza Wagon , '05 LGT |
It's going to be big. It's going to have a RWD specific engine subframe, maybe. It's going to have all the good airbags, I hope. It's going to be heavy, like the Legacy. ... ... Unless they make it Mid-Engine RWD and for 2. Ya rioght... |
#1473 |
Member#: 75146
NWIC
I do hope I'm wrong...
#1474 |
Member#: 135059
#1475 |
Member#: 120244
NWIC
Vehicle:2006 Legacy SE sedan 2006 Outback 3.0R |
I'd wager that SOA Blog's post from 9:30 this morning is more up-to-date. *shrug* I could be wrong.
