Old 05-28-2008, 02:14 PM   #1
douginportland
Member#: 180950
Default newbie doesnt know which forum to look in for code resets
Hi and thanks for reading;
I bought a 97 Outback (autimatic transmission) in nice shape but test drove it in the day time and later after purchase while driving at night there were no instrument lights. Found that the fuse was missing altogether and replaced that. While under the dash I noticed unplugged green male /female clip wires. This was above the gas pedal more or less. I plugged it together and the check engine light started blinking. I used my auto Xray to pull the codes ( finally a reason to use it ! ) and got the speed sensor malfuntion code P0500 and and something else called a neutal position inhibiton switch circuit fault P1121 ? Also a P1540 vehicle speed sensor 2 range/ performance. Can I pull the ECU to reset ? Is it straightforward job to replace speed sensors ?
thanks again
D
douginportland is offline   Reply With Quote
Old 05-28-2008, 02:20 PM   #2
hypoxvi
Member#: 173002
those green connectors aren't supposed to be connected, they are the test connectors. your scan tool should also clear codes, clear them and see if they come back.
hypoxvi is offline   Reply With Quote
Old 05-28-2008, 02:22 PM   #3
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
The green plugs are for diagnostics use only.. leave them unplugged. The CEL is supposed to blink when they're connected.
To reset the ECU, just unplug the battery, step on the brake pedal and reconnect the battery after a few minutes.
As long as your speedometer is working, I'd chalk the codes up to plugging the diagnostic connectors in. See what codes you get after you've reset the battery and left the green plugs disconnected.
Old 05-28-2008, 02:29 PM   #4
douginportland
Member#: 180950
Default that worked
Thanks guys for a quick reply. It worked but I have to back to class I'll let you know how it went.
D
Looking to purchase a 06 wrx 5spd in june or july. what to look out for? Ahut2000 General Community 0 04-09-2008 10:06 AM
Don't know what kit to look for 08 forester subielove02 Brakes, Steering & Suspension 2 03-25-2008 11:00 PM
Which fuse to tap in to for 12v WRX4eva Interior & Exterior Modification 6 07-13-2007 01:15 AM
Where to look up dealer code? balajc General Community 0 01-23-2003 09:58 AM
which one of you Chi guy's is going to trade in for an EVO 10th Warrior Mid West Subaru Owners Club Forum -- MWSOC 18 10-27-2000 07:10 AM
