Old 05-28-2008, 04:25 PM   #1
kilowhisky
Member#: 134144
Thumbs up 2002: Auto to manual wiring diagrams located here.
Just finished my swap and i figured i'll clean up my wiring diagrams and save some people some time digging through all the diagrams to find what they need. This is outlining WRX auto to 5 speed conversion. Most of the wires you can get away with 16-18Ga wires but i used 14ga for the power and ground on a bunch of things just for overkill.
^I'll take this one and combine it with the other diagrams latter.
There are still a few more diagrams that i need write up. I think its just the cruise control and abs. Hope this helps.
kilowhisky is offline   Reply With Quote
Old 05-29-2008, 01:06 AM   #2
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
looking forward to the ASB one please !!!
And70 is offline   Reply With Quote
Old 05-29-2008, 02:15 AM   #3
kilowhisky
Member#: 134144
I haven't quite figured the abs out yet. But i know what i have to do. I just have to figure out if i can tap an existing wire or i have to install some sort of relay. I just have to mimmic the missing sensor which i should be able to pull from another sensor that does the same thing or even the motor relay if i have to. In theory there has to be something that has it.
EDIT: I think i have found a candidate for testing. Going to try it saturday.
Old 05-29-2008, 03:49 AM   #4
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
Sounds good - look forward to the update
only 2 weeks till my 01(aust bug eye) auto goes 6 speed and the ABS is the only real thing worring me !!!
Old 06-03-2008, 11:52 PM   #5
kilowhisky
Member#: 134144
Well my attempt failed. I'm back to square one. Now i have to find time to work on the issue.
Old 07-01-2008, 04:04 AM   #6
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
any more luck?
Old 09-08-2008, 06:31 PM   #7
crispy06
Member#: 154436
I'm actually do 4eat to sti 6speed conversion myself and I'm wondering wat is this rewiring for? Is this to replace the 4eat ecu with a manual ecu?
crispy06 is offline   Reply With Quote
Old 09-08-2008, 06:41 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The ECUs in an 02 are the same for autos and manuals.
auto to manual wiring LegacyWRX Transmission (AT/MT) & Driveline 2 01-21-2007 07:45 PM
2004 service manual wiring diagram joefitz Electrical & Lighting 3 11-16-2006 11:40 PM
Wire Help! auto to manual! JDM Importers Transmission (AT/MT) & Driveline 0 06-21-2006 12:17 PM
4eat manual, wiring diagrams... Jessie James SVX Forum Archive 2 04-27-2001 01:14 PM
Is it possible to change from auto to manual? Andrew General Forum Archive 14 05-26-2000 11:18 AM
