Welcome to the North American Subaru Impreza Owners Club Thursday July 10, 2014
Old 05-28-2008, 09:22 PM   #1
Javi_LGT
Member#: 157069
2000 LGT r.i.p. WRX
Default HELP !! irratic idle problem ???
ok i have a 02 ej20 swapped lgt and recently my motor has been having a rough idle . everytime i start up as the car is idling the rpms kinda fluctuate between 700- 1200 rpms . recently i changed my spark plugs to ngk iridiums and erased a CEL for my 02 sensors thats about it . can anybody possibly knw wats wrong
Javi_LGT is offline   Reply With Quote
Old 05-29-2008, 12:03 AM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
rexman2002 is offline   Reply With Quote
Old 05-29-2008, 12:16 AM   #3
Phil04
Member#: 173686
04 WRX -Stg 2.
Do you have a BOV or could there be a vacum leak?
Phil04 is offline   Reply With Quote
Old 05-29-2008, 11:42 AM   #4
frdawg
Member#: 24129
2002 wrx,EVO3 big16g
WRB 4.444fd Enginuity,E85
try cleaning the iac valve,, a dirty one will cause crappy idle, also if you have a bad front o2 sensor, that could cause it too,, did you get the cel for o2 sensor heater? that usually indicates its toast
frdawg is offline   Reply With Quote
Old 05-29-2008, 02:45 PM   #5
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
the car does not take readings from the front 02 when its still cold, so i doubt this is the issue if it happebns at cold idle
ProdriveDreams is offline   Reply With Quote
Old 05-29-2008, 03:19 PM   #6
white2002rs
Member#: 101491
2002 wrsti
wrb
maybe if you give me your fmic , it will fix the problem....j/k.......... check for vacum leaks , make sure you dont have any more codes
white2002rs is offline   Reply With Quote
Old 05-29-2008, 06:58 PM   #7
03Bugeye
Member#: 169588
2003 WRX
duh, its called open loop.
03Bugeye is offline   Reply With Quote
Old 05-29-2008, 10:45 PM   #8
BluScubi
Member#: 162726
2009 LGT
QSM
Dirty MAF? Throttle position sensor going out? You could have either one but not have a code for it. Some times a dirty throttle plate can screw up your idle too. Does the idle even out once the car warms up?
BluScubi is offline   Reply With Quote
what to check for irratic idle and stalling? jacky599r Factory 2.5L Turbo Powertrain 14 01-27-2009 01:05 PM
Swapped engines, now need help isolating idle problem smokybay Impreza Forum 2 07-27-2007 06:06 PM
need help with idle problem legacytuner671 Factory 2.0L Turbo Powertrain 9 12-27-2006 04:44 PM
Help, low idle problem Goofy's WRX Factory 2.0L Turbo Powertrain 8 07-27-2006 04:29 PM
Irratic Idle Problem, Pressure from gas tank. pdigiacinto Legacy Forum 6 04-20-2004 08:22 PM
