Notices
Old 05-29-2008, 01:38 PM   #1
nismo4life
Member#: 118317
Default Cruise control conversion
I am looking to adding Cruise Control to my 2002 TS wagon. I tried looking for kits from Subaru but no luck anywhere. I have found pieces on ebay though so my question is, Besides the control motor w/ cable and the control unit, that else will I need. The steering wheel control and the Cruise button that goes on the lower part of the dash right...is that it?
Oh, and will WRX cruise control parts work on my TS wagon? I don't see why they would be different as long as its from a 5spd wrx. Anwsers are much appreciated, thanks.
nismo4life is offline   Reply With Quote
Old 05-29-2008, 05:03 PM   #2
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
they the same if i remember right
mikeis300 is offline   Reply With Quote
Old 05-30-2008, 12:46 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
as long as its pre '04 yes this should work, and i think you mentioned everything
ProdriveDreams is offline   Reply With Quote
Old 05-30-2008, 04:50 PM   #4
nismo4life
Member#: 118317
Will the harness for the cruise button on the dash and in the wheel already be there?
Old 05-31-2008, 01:13 AM   #5
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
not positive, but for things like this subaru usually only makes one harness as its more expensive (read ford-like) to make two.
PM me your email if you want a wiring diagram of a given model and year.
easiest way disconnecting cruise control cable from TB, cruise control removal 02-03 fastwrx25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2008 07:30 PM
UTEC: If the cruise light is flashing....cruise control doesn't work? bpwatts Engine Management & Tuning 4 07-10-2006 07:07 PM
Cruise Control Aint Cruising ahawks Service & Maintenance 0 10-21-2005 01:12 PM
Cruise actuator but no cruise control!! Improviser Normally Aspirated Powertrain 14 11-13-2002 04:48 PM
