Old 05-29-2008, 01:52 PM   #1
kakarotoni
Member#: 156240
02 WRX
06 Impreza
Default Apexi Turbo Timer Problem, Broken?
I have an apexi turbo timer in my 02 wrx. I've had the WRX for a year and the turbo timer was working great until a month ago. There are times where when I start my car that the turbo time would not activate or light up. And times where it would activate and light up. I have notice it flickering and shutting off. And I notice when I start my car up it does not come on, but when I turn it off, it happens to come on out of no where?
My battery is running between 13-14 volts. Not sure if this will effect the turbo timer and cause it to malfunction. I don't think its a loose wire but its a possibility, I've never seen any turbo timers do this. I am also running a police radar from my cig lighter but I unplugged that to see if it was interfering with the turbo timer and it didn't change a thing.
If anyone has any ideas or suggestions please lemme know. And please dont suggest to buy another turbo timer, theres no reason why it should be broken.
kakarotoni is offline   Reply With Quote
Old 05-29-2008, 07:15 PM   #2
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
check your leads, make sure the wires are soldered and secured properly. flickering means there is a loose connection
mikeis300 is offline   Reply With Quote
Old 05-31-2008, 12:38 AM   #3
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Mine did the same thing... ended up being the BLACK box that comes with the turbo timer... Needless to say I just bought a new one for $70...
But yes I know what your talking about and mine did the same thing...
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 05-31-2008, 03:11 AM   #4
SoCalBullet
Member#: 100729
2007 STI
I would first start with checking the ground. You may not have a good ground and that will definitely cause intermittent problems. Be sure you have a good ground connection and then check the +12V line for constant power.
SoCalBullet is offline   Reply With Quote
Old 05-01-2010, 06:46 PM   #5
kevster02wrx
Member#: 245664
2002 Subaru WRX
Unhappy apexi turbo timer
hey, i also got an 02 wrx with an apexi turbo timer, and i was just wondering wether or not someone has experienced my problem. Sometimes my timer starts counting down right after i started it. and its been doing it alot more lately and its starting to become a reall pain in the ass. any ideas why it might start counting down everytime i start the car? also, my battery is getting drained, which i may think is from the black box the timer is connected too. i figure the relay in the box may be the issue. any ideas?
kevster02wrx is offline   Reply With Quote
Old 05-04-2010, 12:39 AM   #6
kakarotoni
Member#: 156240
02 WRX
06 Impreza
^^^ Well I had similar problems like that but really right now the whole apexi turbo timer just comes on and shuts off when it pleases, there really isn't anything that can trigger it that I've noted. It's just pure random.
Old 05-27-2010, 02:33 PM   #7
240sxsexy
Member#: 222487
Mine randomly doesnt count down all the way when I turn the engine off... Whats strange though is if I turn the key to power the radio/ect (but dont start the engine) and then turn it off the turbo timer will count all the way down pefore killing power.
I checked to see if mine was a fake and its 100% legit.
240sxsexy is offline   Reply With Quote
Old 06-08-2010, 02:13 PM   #8
NewShockerGuy
Member#: 40736
2005 WRX STI
It's probably the black box...
My friend had the same issue and just like mine it was the black box or components inside.. I took it apwart and noticed that some of the PCB board was darker than usual and after flipping the underside out saw burnt traces...
-Nigel
Old 06-13-2010, 08:28 PM   #9
240sxsexy
Member#: 222487
I'll check it out. Thanks.
RS C/F guage pod, apexi RSM, Apexi turbo timer, and Expired sabelt harness scobaru Interior/Dressup/Audio & Security 8 06-23-2008 10:38 PM
FS: Apexi AVCR + Apexi Turbo Timer (2x) SlammedREX Engine/Power/Exhaust 16 09-17-2007 01:38 PM
RS C/F guage pod, apexi RSM, Apexi turbo timer, and Expired sabelt harness scobaru MWSOC Private Classifieds 10 04-13-2007 03:50 PM
Apexi Grounding Kit and Apexi Turbo Timer Flybert Engine/Power/Exhaust 0 09-24-2006 08:28 PM
Autometer Gauges, Apexi AVCR, Apexi Turbo Timer, a-pillar, etc.. zroom tsuchiya Private 'For Sale' Classifieds 37 04-06-2006 11:23 PM
