Old 05-30-2008, 03:17 AM   #1
CharT
Member#: 36117
2003 WRX Wagon
Default Two hours to press front wheel bearings?
After being inspired by the wheelbearing thread in the suspension forum and having gotten fed up with brakepad knockback, I decided it was time to replace my front wheel bearings. Removing the suspension knuckles was a real adventure but the information on NASIOC helped me through as usual.
After removing the knuckles, I cleaned and dropped them off at a local shop on my way to work. I get a call later in the afternoon telling me that they're done. The shop tells me it's two hours labor, or $170. I was very surprised as all my research has indicated that pressing the bearings out/in was a quick job, especially for a shop that specialized in Subarus. I asked if there was anything wrong with my parts and they said everything was fine. I spoke with the technician that did they work and he explained that it took a long time to set up the press and to ensure that the bearing goes on straight. I don't mind paying to have the job done right, but is two hours of labor reasonable for pressing bearings?
CharT is offline   Reply With Quote
Old 05-31-2008, 12:03 AM   #2
DCales
Member#: 131509
2006 Impreza WRX
I would not be to concerned with the labor charges. I have pressed many bearings during my years as a tech and some can be a major pita. I would imagine that if they did the full job inluding removing both knuckles they would have charged 5 or 6 hours. I had a saturn wheel bearing explode while installing it using a Hub shark tool and it hit me square in the face... so the money spent is well worth it.
DCales is offline   Reply With Quote
Old 05-31-2008, 04:47 AM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I did a bearing with a Ford tech at a dealership one day, just a single side, but he didn't have the right dies and had no clue how the thing was supposed to come apart.
Still took him less than 30 minutes to remove and reinstall one side, and again, he was 100% clueless as to how to do it.
/Brox
Broxma is offline   Reply With Quote
Old 05-31-2008, 10:24 AM   #4
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Perhaps they have a 1-hour minimum charge?
bulwnkl is offline   Reply With Quote
Old 05-31-2008, 01:01 PM   #5
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^ this. But in most cases it should be an hour or less. There are some times the hard ones that nothing goes wrong but just are stubborn and take a long time. $170 does seem stiff to me, but when it is all said and done, it is DONE.
flstffxe is offline   Reply With Quote
Old 05-31-2008, 04:27 PM   #6
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
understand that they do not generally charge extra when it is difficult to remove except in extreme cases. This is the way the flat-rate world works, just cause yours take a half hour doesn't mean thats what they charge. The idea is that while yours may take a half an hour someone else's will take an hour and a half this way the pay is "relatively" fair for the tech. also just because hes a great tech and can do the job faster does not mean that he should get less money because it took him less time.
2 hours does seem a little high, but not outrageously.
also disregard the ford comparison, as different manufactures do things VERY differently.
ProdriveDreams is offline   Reply With Quote
Old 06-01-2008, 10:49 PM   #7
CharT
Member#: 36117
2003 WRX Wagon
I guess the lesson learned here is for me to get multiple quotes upfront, but since this was a reputable Subaru shop who builds Subaru race cars, I figured the job will be done right. I was rushed on my way to work and, as flstffxe says, atleast it's DONE! I just don't like the feeling of being taken advantage of; or even the suspicion of it.
My final thing to do is find someplace to press in the front lateral link bushings off the car. Then the entire car goes back together and on the road again!
Old 06-01-2008, 10:54 PM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Which bushing do you really mean as there officially isn't a front lateral link.
Old 06-01-2008, 11:25 PM   #9
CharT
Member#: 36117
2003 WRX Wagon
I'm not sure what they're called officially, but there are two sets of lateral links in the rear suspension. One set has the swaybars attached and they are more towards the rear of the car, so I call that set the rear lateral links. The front lateral links that I'm referring to don't have the endlink mounts and are mounted forward of the other.
There are four lateral link bushings that came with the Subaru sport suspension kit. Two of them are in a single bag marked Bush B and the other two are individually packed, labelled Bush A. I got these bushings nearly 3 years ago as a reward for helping someone install his swaybar. Must be some kind of record to finally installing these things.
He also gave me four metal bushings(20166FE100) labelled "Pipe MTG (Bush)." Those look impossible to install so I'm not even going to try. Maybe I'll find somebody that wants them as I can't believe anybody would pay Subaru $22 a piece for these paperweights.
Old 06-01-2008, 11:30 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Ah, then you actually used the right words. Since you had been talking about front wheel bearings, it seemed to follow logically that you were still talking about the front end of the car.
As far as getting those bushings in, take a look at this handy dandy tutorial on how to do it
Old 06-02-2008, 02:08 AM   #11
CharT
Member#: 36117
2003 WRX Wagon
Thanks for the link! You did a tremendous job on that tutorial. As it turns out, I happen to have the "taco link" but without the cheese dip, hehe. As I don't plan on doing this more than once, I'm debating whether I should buy the Harbor Freight press or have a shop do it. The cost will probably come out about even unless I do more bushings later on.
Old 06-02-2008, 02:11 AM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You can "rent" that press at Advanced Auto (and probably every autoparts store). You just ask for the loaner ball joint press and look inside the box to make sure what they give you looks like the picture. You give them the full purchase price of the tool, then they refund the entire amount to you when you return the tool.
If you have the taco link, it's REALLY worth upgrading.
Old 02-12-2009, 11:40 PM   #13
jasonspeed
Member#: 187971
03 Grocery Getter
subyshop.com
Thank GOD for Auto Zone's rent-a-tool deal, I'm changing a bent traverse link out this weekend. Only $133 gets me the tool for the weekend. I'll take some pictures and put them up here to help anyone who would like a better visual guide than the tech manual.
jasonspeed is offline   Reply With Quote
Old 02-13-2009, 07:58 PM   #14
johnniebravo
Member#: 79626
2005 WRX
Platinum Silver
I think 170 is a lot, I bought a press and everything I needed for less than 170!
johnniebravo is offline   Reply With Quote
Old 02-15-2009, 07:10 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
2 hours is crazy. If you have a press and the right size dies you can do a side in 15 minutes.
Tony
Old 02-16-2009, 12:22 PM   #16
aprezzal
Member#: 126480
1993 Impreza L FWD
Red
It took me about 2 hours and I dont have a press. Just a large vise and alot of improvisation. But again it is done and done right as opposed to mine which im sure is a bit wanked from the medieval method I employed.
aprezzal is offline   Reply With Quote
Old 02-16-2009, 03:28 PM   #17
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
the hard part is getting them out. The suby manual says inorder to remove the inner race, you have to cut it. This can be a gigantic pain, as I did it this way the first time I did bearings. I gave that shat up and bought one of these: http://www.harborfreight.com/cpi/cta...temnumber=3979. This was $15, plus a harborfrieght shop press on craigslist for $50, I only spend $75 for the proper tools.
http://www.harborfreight.com/cpi/cta...emnumber=33497This is the press I have, 12 ton for bearings is an absolute MINIMUM.
Bacon117 is offline   Reply With Quote
Old 02-19-2009, 12:18 AM   #18
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Which manual says you have to cut the race out? None I have.
My manual also says that no more than 3 tons should be used to press the bearings in, so 12 ton is overkill.
wobbletop is online now   Reply With Quote
Old 02-19-2009, 12:37 AM   #19
plode
Member#: 116910
FWIW, I know its not a suspension part, but I used to press out/in new bearings into pumps for jet ski's. I was a "new" mechanic and still could replace 2 bearings in less than half an hour.
plode is offline   Reply With Quote
Old 02-19-2009, 12:41 AM   #20
plode
Member#: 116910
You don't actually apply all 12 tons of force to the bearing. You simply use the amount of pressure necessary to get the bearing to seat where it's supposed to.
Having the ability to use 12 tons of pressure is handy depending on what you're working on.
We had a 50 ton press at work.
Old 02-19-2009, 04:41 PM   #21
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
yea, sorry, the suby manual says "use a suitable tool". I was thinking of the factory manual for my sisters minivan, says to cut the inner race. It's stupid, don't do it.
The bigger the press, the easier it is on the installer. with the 12 ton hydraulic, i was working a little hard toget it to press. A 50 ton would be even easier.
Old 01-13-2010, 03:13 AM   #22
ChrisRT
Member#: 125941
200x WRX
Bump for wicked slick info.
I need to know a few things here.
1. All one needs is a press and a large bearing separator?
2. Does the press really have to be 12tons? I mean a 5ton press should suffice, no?
3. Is it real easy to **** up a bearing while putting it in? They tend to cost over 50 for just 1 hub.
ChrisRT is offline   Reply With Quote
Old 01-13-2010, 04:59 AM   #23
subi400
Member#: 216984
1996 Impreza outback
Green
My friend Scott and I changed a wheel bearing in my impreza in like 10-15 minutes after getting the hub out. And yes, you do not have to cut the inner race, you can get a race seperator at most auto parts stores, they are like reverse pliers. Another thing is that a 12 ton press or a little larger is better because of the height available to work with.
If you want a good press for doing bushings and such, using a 2 ton press I believe is sufficient.
subi400 is offline   Reply With Quote
Old 04-11-2011, 10:57 PM   #24
Dirty B Racing
Member#: 253029
Default frustrated
I have a 2.5rs
I am very frustrated I had my rear wheel bearing replaced at a shop 2 years ago, and now there so much play im scared to drive it. Does anybody have any suggestion on high performance bearings so maybe they will last longer then two years?
Dirty B Racing is offline   Reply With Quote
Old 04-12-2011, 02:13 AM   #25
Buffman
Member#: 189212
2002 WRX wagon
I've always used timkens with good success.. Perhaps some debri during installation got into the bearing? I had an instance of the little spring for the seal getting sucked into the bearing, and after 2yrs destroyed it..
Buffman is offline   Reply With Quote
How tough is it to do front wheel bearings? Patrick Olsen Brakes, Steering & Suspension 16 11-23-2009 05:21 PM
Looking for mechanic to replace front wheel bearings. unknownazn77 New England Impreza Club Forum -- NESIC 8 06-02-2009 03:47 PM
Where to get a wheel bearing pressed ? Gonz Mid Atlantic Impreza Club -- MAIC 16 08-02-2006 06:09 PM
san jose - place to get new wheel bearing pressed in? spitfirezip100 Brakes, Steering & Suspension 1 06-19-2006 11:03 PM
are front wheel bearing on Impreza'a press in bearings? Homemade WRX Transmission (AT/MT) & Driveline 7 10-22-2004 09:33 AM
