Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 05-30-2008, 03:33 PM   #1
get'erdone
Member#: 67200
2004 WRX
TiC Tok'd evoIII
Default problem with camber bolt fitment
I have a 2004 WRX with Tokico D-Spec struts, and I bought some aftermarket camber bolts for the rear. SPC is the bolt Co.
The tech at Firestone said he couldn't fit the bolt, as he said the tab wouldn't go in without hammering the bolt in the hole--essentially he claimed it didn't fit. I reconfirmed with my vendor that the camber bolt was the correct model.
Has anyone had a problem getting the bolt + washer tab in? Does it require "hammering" or should he have been able to fit it?
get'erdone is offline   Reply With Quote
Old 05-30-2008, 03:46 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Just took these after reading your email.
Old 05-30-2008, 03:54 PM   #3
sigurd
Member#: 128721
2002 impreza WRX
psm
Thats what I thought when I first tried to install them too.
You accually do have to hammer them in. Just tell them to line the little tab with the top of the cam lobe and hammer it in. Its a very snug fit when its going through the hub.
Make sure the lower bolt is loose too so it can center itself as you hammer it.
sigurd is offline   Reply With Quote
Old 05-30-2008, 07:06 PM   #4
get'erdone
Member#: 67200
2004 WRX
TiC Tok'd evoIII
In a word, perfect. Thank you, TiC for the pics (and the suspension) and Sigurd for the advice.
Old 05-30-2008, 07:10 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
No prob. I didn't get a call from you so I figured you saw the pics.
Camber Bolt Fitment wordlifewrx Brakes, Steering & Suspension 8 06-23-2009 12:03 AM
Camber Bolt Fitment Prob with '05 WRX jmhubbard01 Brakes, Steering & Suspension 9 10-29-2006 09:14 AM
rear alignment problem. is camber bolt enough? S.G.D Brakes, Steering & Suspension 37 07-03-2006 07:22 PM
Removing Negative Rear Camber with camber bolts? NicGordon Brakes, Steering & Suspension 1 08-15-2003 12:39 AM
Can only get 0.5 negative camber with camber bolts? Tronner Brakes, Steering & Suspension 1 08-23-2002 08:56 PM
