Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Closed Thread
Old 05-30-2008, 09:14 PM   #1
Member#: 161832
2000 Outback Limited
Default Spark Plugs
i am getting HG's done monday and wanted to do spark plugs at the same time. i have been recommended iridium, not platinum. is this what most people use?i am between NGK, BOSCH, and DENSO. also am between 1 and 2 tips. let me know which u have or ones not mentioned u have heard good things about. thanx
PA-Outback2000 is offline
Old 05-30-2008, 09:21 PM   #2
Member#: 53443
2001 LL Bean Outback
I would stick with the NGK and either the platinum or iridium will be fine. The iridium should last longer is all.
Cougar4 is offline
Old 05-30-2008, 11:45 PM   #3
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please refer to the Service and Maintenance forum and the sticky/FAQ threads therein.
Mulder is offline
Closed Thread
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 712 10-17-2016 05:27 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
