Old 05-31-2008, 10:12 AM   #1
WRXislander
Member#: 50064
'02 WRX
MBP
Default Confused about STI pinks economy map
Posted this on Cobb's website but it takes quite a while to get a response there.
I'm confused about whether or not I can run this with my vf39. I have an '02 w/a version 1 Accessport.
At the top of p.2 in the map notes it says,
"1.01 - Original map. Built specifically for those using STI injectors and VF-series turbos."
Then at the bottom of the page it says,
"For use with Denso STI pink fuel injectors & stock turbo only."
What gives? Does it work or doesn't it? Does version 1.30 not work with a VF-series turbo like the map was originally planned for? Gas prices are through the roof and I have too take a 2000+ mile road trip soon. Would love to be able to use this map!
WRXislander is offline   Reply With Quote
Old 05-31-2008, 11:18 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
as long as you have the correct injectors the map should be fine, the econ maps run 0 boost control, and all you will get is wastegate boost
a6n6d6y is offline   Reply With Quote
Old 05-31-2008, 04:07 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
dont worry about the turbo, as long as you have pinks youll be fine, the map notes have a good number of typos and oopsies in them
like look at the VF-39 DW injector map notes... it states you need pinks to run it...
ProdriveDreams is offline   Reply With Quote
a bit confused about real vs. base maps freezer16801 AccessPort 4 11-05-2008 05:32 AM
Confused about STi wheels.... JoeSUBARU Tire & Wheel 2 11-08-2007 11:43 AM
04 STi utec economy map intpostman23 Engine Management & Tuning 10 09-07-2005 10:17 PM
Confusion about STi pinks wrxfactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-20-2004 09:59 PM
Confused about STI GroupN tranny mount Autologic Transmission (AT/MT) & Driveline 2 12-03-2003 04:07 PM
