Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-01-2008, 12:02 AM   #1
Chuck Annicelli
Member#: 3265
2013 WRX Hatch ISM
2013 Outback Limited
Default 02 wrx fogs
I am going to put 4 Hella 1000's on my car. Will I be able to do this without any electrical problems? Will the extra 200 watts cause any problems with fuses etc? Is there anything I have to add or change for this extra electrical usage?
Thanks in advance,
Chuck
Chuck Annicelli is offline   Reply With Quote
Old 06-01-2008, 12:56 AM   #2
NOboostSUBIE
Member#: 163322
2002 PSM Impreza RS
DD & Weekend Auto-x'r
I would advise upgrading the wiring to 12g or even 10g depending on the wattage of your bulbs and I can't speak to much about the pull on the alt. and fuses....anyone else?
NOboostSUBIE is offline   Reply With Quote
Old 06-01-2008, 06:57 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Install new wiring with a relay to draw the power directly from the battery. Do NOT rely on the existing fog light wiring, it is not adequate for this.
Old 06-01-2008, 11:51 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I agree with Mulder. You will need run an entirely new fused circuit from the battery to support that much power. As mentioned in an earlier reply, using 12ga wire will work fine for this application. I assume you will also be using a relay to control the power to the lights since this will be too much current for a normal switch to deal with. If you leave other high power accessories OFF (including the headlights, but not absolutely necessary) while using the lights then you may get by using the original alternator.
Old 06-01-2008, 07:29 PM   #5
Chuck Annicelli
Member#: 3265
2013 WRX Hatch ISM
Thanks everyone. Although I think I asked that question without thinking it through. I have the Halla FF1000 Free Form Driving Lamp System and it comes with the wiring harness, switch, relay and fuse.. I am planning to get a light bar for it and was thinking I was going to tie it in with my fogs... I am not, I will have them on their own system.. It was pretty late when I posted that..
Thanks
Chuck
Old 06-02-2008, 03:58 AM   #6
subaru3169
Member#: 55252
* pullup bar *
upgrading to a beefier alt and battery would be a good idea prior to installing all those lights as well
subaru3169 is offline   Reply With Quote
Old 06-02-2008, 02:11 PM   #7
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
Thanks
Chuck
the included wiring may be a little questionable.
for 4 lamps i would use my own 12g wiring and some bosch relays.
dont know about hella's harnesses, but most of them that come with aux lamps are total junk.
jdubya301 is offline   Reply With Quote
Old 06-03-2008, 01:23 PM   #8
Chuck Annicelli
Member#: 3265
2013 WRX Hatch ISM
Thanks, this is sort of what I meant to ask on my original question. I figure around 220 watts more of lighting might cause some problems but was not sure. I would rather not replace my alternator.
jdubya301 I will have to take a look to see how that stuff looks. Not sure if anyone on here has the 1000's and used the supplies that come with it? Maybe someone with the 1000's can chime in?
Thanks again.
Chuck
Old 06-03-2008, 08:36 PM   #9
subaru3169
Member#: 55252
* pullup bar *
the wiring hella provides seem quite adequate for those lights.. i've got 2more sets lying around myself, but i'm not putting 'em on yet.. they are very very much beefier than any oem wiring.. so i wouldn't worry too much about it.. unless you're using some high wattage bulbs or hid lights or something
a beefier alt isn't really all that much expensive compared to others.. maniacelectronics sells reconned ones but with higher amperage for relative cheap.. that's my next step
Old 06-03-2008, 09:43 PM   #10
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
Thanks again.
Chuck
i have ff1ks but i let the guy who sold em to me kep the wiring harness. sorry!
Old 06-03-2008, 11:01 PM   #11
Chuck Annicelli
Member#: 3265
2013 WRX Hatch ISM
Thanks for the heads up. I will keep that in mind..
Old 06-03-2008, 11:13 PM   #12
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
no prob. the only reason why i worry about the wiring that comes with aux light kits is the chance of fire. i wouldnt be too worried about hella's stuff, but its just a heads up.
my dad had a cheapo foglight kit in his van, and one day he walked back, and noticed there was smoke coming from under the hood. the relays for the fogs had melted and caught fire. had he not had walked back/had a fire extinguisher, the van woulda been toast.
Old 06-05-2008, 04:51 AM   #13
subaru3169
Member#: 55252
* pullup bar *
was it a hack job or was the wiring done correctly?? or was the problem just crappy wires??
that sucks, man.. that's almost kaboom!!
Old 06-05-2008, 02:07 PM   #14
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
no hack job, it was just the substandard wiring/relay that came with a cheapo (40$) streetglow foglight kit. my dad even had it installed professionally at a car/audio place.
Wtb: Stock 02 Wrx Fog Light(s) jgiffy1 Canada Region Forum 8 01-31-2003 10:40 PM
Wtb: Stock 02 Wrx Fog Light(s) jgiffy1 Vancouver Impreza Club Forum -- VIC 10 01-31-2003 12:42 AM
Wtb-pass side 02 WRX fog light. Sibu Southern California Impreza Club Forum -- SCIC 1 01-28-2003 12:59 PM
02 WRX fog light vickerto Service & Maintenance 2 01-07-2003 03:00 PM
02 WRX Fog Light wattages? andygold Interior & Exterior Modification 3 11-04-2001 11:57 AM
